2012 edge rear view camera problem
any ideas thanks
If you touch radio or any other function, it should switch off and on the other function.
Camera is wired to power whenever the car is in run or start and is switched in the HU.
If you want it to switch off as soon as you put it in drive, I believe you would have to rewire the camera power into the backup lamp circuit.
  • 4 months later...
