2010 Edge SLE Limited
tanman_2006
The procedure is detailed in your Navigation Manual:
1. Press the PHONE hard button on the navigation system.
2. Select the ‘Settings’ tab on the touchscreen.
3. Press ‘Advanced’.
4. Select ‘Vehicle Health Report’.
5. Select ‘Automatic Reports’.
6. Enter the desired setting.
Once you have turned on the automatic report feature, you can then choose at which mileage intervals you would like to be prompted to run a health report.
5. Select ‘Mileage Interval’.
6. Select the desired mileage interval setting.
When the chosen mileage is reached, SYNC will automatically prompt you and ask if you would like to run a health report. You can then accept
and SYNC will send you an e-mail with the information or you can choose to have SYNC remind you later.
