Oil low?
Subaruglenn
Hello everyone
I'm new to the forum and my name is Glenn
I just traded in my kia for a 2011 edge sport with 42000 Kms on it and they told me the changed the oil and have a sticker for when it needs to be changed and after a day and a half the low oil light is on it still has ford warranty but I'd like to know if this a common problem thanks for any help
Is it the oil change reminder light on by any chance? That needs to be reset every time the oil is changed. What you are referring to would be this:
Engine oil pressure (RTT):
Illuminates when the oil pressure
falls below the normal range, refer
to Engine oil in the Maintenance
and Specifications chapter.
  On 5/13/2015 at 1:51 AM, Subaruglenn said:
Hey thanks for the response
I did forget to mention that I was just listening to the radio with the engine off
Yep, my wife called me up in a panic once for this same reason. Just like any vehicle, the oil pressure light will come on when the ignition is in "ON" and the engine is not running. DIfference in the Edge is that it pops up a big message in the cluster instead of just the small red light that you might be used to.
