kc300c Posted May 12, 2015 Report Share Posted May 12, 2015 Totally PLUG & PLAY Direct Replacement LED Tail lights for 2007-2010 Ford EDGE – All models Easily replaces the stock tail light assembly on the 2007-10 Ford EDGE (All models). No additional wiring or need for resistors. Just unplug your old stock light and plug in ours. Integrated position, brake and turn signal functions Check them out at www.DriveBright.com Check out the photos and videos below: 1 Quote Link to comment Share on other sites More sharing options...
thirdgenlxi Posted May 12, 2015 Report Share Posted May 12, 2015 That's pretty cool.... I like it! Might have to pick up a set here at some point Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted May 12, 2015 Report Share Posted May 12, 2015 Do it, Jared, do it!!! Quote Link to comment Share on other sites More sharing options...
thirdgenlxi Posted May 13, 2015 Report Share Posted May 13, 2015 On 5/12/2015 at 8:05 PM, WWWPerfA_ZN0W said: Do it, Jared, do it!!! LOL...... I've gotta buy a house first, and that's about to swallow my whole wallet and bank account whole Quote Link to comment Share on other sites More sharing options...
RustyEdge Posted May 13, 2015 Report Share Posted May 13, 2015 Hey Dan, I had posted this in another topic, but I found the Diode Dynamics Tail-as-Turn module (DIY kit) and wondered if we would be able to wire you're DTBL tails for the '11+ to integrate the turn signal into the brake light. http://www.diodedynamics.com/store/catalog/product/view/id/21872/s/tail-as-turn-module-diy/category/1441/#!prettyPhoto Looks like you did this here, any chance that you could advise on how to wire it properly? or maybe offer a kit yourself that would give us the same effect? This would open up the existing turn signal bulb for an additional reverse bulb (which you could package the bulbs together ) Everyone is looking for more light out of their reverse bulbs, and while the LED's you have are great, doubling the amount of bulbs would be even better! Thanks, -Russ Quote Link to comment Share on other sites More sharing options...
inthefuture1955 Posted September 13, 2018 Report Share Posted September 13, 2018 (edited) I have a 2013 Edge with these. There are well worth the price. I put in LED 3157A and 5000K backup lamps in to complete the set up. These replacement units have the factory look to them. These pretty much match the look of the 2016+ Explorer tail light with the halo-style parking lamps. I also installed the front lower valance modules. They change from 5000K to amber with the turn signal. I also installed 3157A/W Switchbacks. My headlights are 5000K LED's and I replaced the Puddle Lamps with Drive Bright LED modules. I have 2 friends with Edges. One has already installed these in his 2007 and my other is ordering a pair for his 2009. They decided to order them after seeing mine. I also show them to every Edge owner I meet and they always want the company information. I highly recommend the Drive Bright product line for any '07-'14 Edge. 2013 Mineral Gray SEL, LED exterior lamps, ConsoleVault, Ford Remote Start Edited September 13, 2018 by inthefuture1955 1 Quote Link to comment Share on other sites More sharing options...
