2015 Edge Sport Towing
Thanks. Same here. If I get my truck done in time I will be going to PA next weekend with the ski. Lake Wally
Sounds like a good time. When I lived up in Michigan, we had jet skis and would be using them all summer long. Once I moved to this area, it was impossible to keep them. Storage was an issue and very costly. Plus access was not as easy.
So now I just paddle my canoe around
Thinking about doing this to mine. But I wasn't sure if anyone has any idea about warranty. Like you I will be pulling a single motorcycle and trailer (hardly much weight at all).
It won't void your warranty. And if they try to say it does, they have to prove how adding a hitch resulted in whatever issue you are currently having.
Did you get the same part number as Natem?
Yes, got the hitch and harness from curt. The part numbers are 13224 for the hitch, and 56272 for the harness. Was $200 shipped (Canadian). Pretty good deal!
I was thinking about going with the hidden hitch but it actually looks like the curt is covered more.
