How to Replace Outside Mirror Turn Signal
Just noticed our 2013 Edge's right outside mirror's turn signal light has somehow been pushed into the mirror housing. The housing is ok, no scratches on the surface. That turn signal bulb doesn't light up anymore when activating the turn signal. The rest of the functions of the mirror are OK: the mirror can be power adjusted and the blind spot indicator works.
I know how to remove the mirror. Before I get into the project, I'd like to know if anyone has had a similar issue or has replaced the turn signal bulb. How do you get to the bulb? Are the bulbs a dealer item? I did a search on the forum but didn't see anything.
Thanks!
