Gmar Posted April 19, 2015 Report Share Posted April 19, 2015 Car has power, horn. But engine does'nt crank. It dont do it all the time. Leave car for a hour it start back. Dealer cant find the problem yet. I used to take of the neg cable from battery. But do not help any more. Move shifter from park to nuetral. Car started. Please help what can bevthe problem. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted April 19, 2015 Report Share Posted April 19, 2015 Probably need to replace the shifter based on your troubleshooting. Normally, we see transmission range sensors causing battery drain, but this could be an early or different version of the same problem. Quote Link to comment Share on other sites More sharing options...
Gmar Posted April 22, 2015 Author Report Share Posted April 22, 2015 Problem getting strainger. Use the car the whole day. Then in the afternoon car wont start again. Have all the necessary power. Try several time car would no crank at all. Tried in the morning again nothing. Called the towing service and send to garage. When car removed from towing truck car started again. Wel wel. Please help Quote Link to comment Share on other sites More sharing options...
akirby Posted April 22, 2015 Report Share Posted April 22, 2015 The shifter may not be registering that it's in Park. Or it's not registering the PATS key. Quote Link to comment Share on other sites More sharing options...
