Replacing headlight bulb
Tried three different bulbs and all were little to no better.Even tried the Sylvania Ultra's
Finally did the LED's from dan@daytimebrightlites.com and they are fantastic!
The best part...simple plug and play install...no wiring issues....and they were only $120.
Dont waste your time on different bulbs...do the LED's from Dan...his service is fantastic !
Just to avoid confusion. Dan's headlight kits are HID, not LEDs.
Ā
HID would represent the biggest lumens/"brightness" increase. However, if you have a halogen reflector (which the 2008 edge does), you will cause issues to oncoming traffic due to the improper light scatter as a result of using HID bulbs in reflector housing.
Ā
You may want to consider upgrading to a projector headlight on your edge.
Ā
VLED.com does sell a true LED headlight conversion kit, which may be better suited for a reflector housing (but I can't back that up with any science nor evidence).
