dacurb Posted April 13, 2015 Report Share Posted April 13, 2015 I have a 2012 Edge SEL. After going to the car wash, I notice that when I lower and raise the driver side window, it comes up with water streaks on it, as if there is is a pool of water inside the door well. Has anyone else run into this? Thanks for any info. Quote Link to comment Share on other sites More sharing options...
gmfranco88 Posted April 14, 2015 Report Share Posted April 14, 2015 dacurb, you most likely getting the streaks from the felt-like material that is located on the inside of the outer panel. If you lower your window you will notice it. As a rule of thumb, I try not to lower my windows after a car wash to avoid the streaks. Quote Link to comment Share on other sites More sharing options...
dacurb Posted April 14, 2015 Author Report Share Posted April 14, 2015 gmfranco88 -- Thanks. I wondered about water collecting in the door well becuase this only happens on the driver's door. None of the windows in the other doors come back up "wet" Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted April 15, 2015 Report Share Posted April 15, 2015 Driver's window gets the most use, so most likely to have "issues" as parts wear over time. Maybe try some silicone lube spray on the rubber/plastic strips to keep them "tight" to the window? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted April 19, 2015 Report Share Posted April 19, 2015 My 09 MKX also has water streaks as well. Pain in the a**, but probably common to this model. Like gmfranco88 I avoid lowering my windows after a car wash as well. Quote Link to comment Share on other sites More sharing options...
