danib1227 Posted April 7, 2015 Report Share Posted April 7, 2015 Good Afternoon All, I have a 2011 Ford Edge Limited with my Touch Sync. As of last week I've been having a problem with the A/C Fan Speed. The ambient Temperature is displaying 46 degrees and every five seconds shows the correct temperature, but cycles back to 46 degrees. If I have the AC on "auto", the ac does not come on. When I take it off of "Auto" to control it Manually, no matter at what fan speed I select, it blows hard then slow in the same rhythm as the Temperature. When it reads 46 it shuts off, when it reads correct it blows hard. Non Stop Repeatedly every 5-7 seconds. Yesterday we also noticed that the Ambient Interior lighting is turning on and off in the same rhythym as well.. Please Help! I just replaced the Ambient Temperature Sensor last night, to no avail. Any and all input is appreciated and will be considered. Thanks! Danny in Florida Quote Link to comment Share on other sites More sharing options...
ls973800 Posted April 7, 2015 Report Share Posted April 7, 2015 Sorry to hear the sensor didn't help you out. So the new ambient sensor isn't showing the correct temp? Just for something to try, check your battery cables to make sure they are tight and not corroded. You might also try unhooking the battery for a few minutes to see if anything resets. Almost sounds like a bad ground somewhere? I don't have my service manual C/D here so I can't look up any wire schmatics to see if there is something common that could cause this. You might even start to suspect the head unit for the HVAC system, but I really don't know. Quote Link to comment Share on other sites More sharing options...
danib1227 Posted April 8, 2015 Author Report Share Posted April 8, 2015 On 4/7/2015 at 10:00 PM, ls973800 said: Sorry to hear the sensor didn't help you out. So the new ambient sensor isn't showing the correct temp? Just for something to try, check your battery cables to make sure they are tight and not corroded. You might also try unhooking the battery for a few minutes to see if anything resets. Almost sounds like a bad ground somewhere? I don't have my service manual C/D here so I can't look up any wire schmatics to see if there is something common that could cause this. You might even start to suspect the head unit for the HVAC system, but I really don't know. It reads correct temperature then changes to 46 degrees.. then normal.. then back to 46 degrees. but Yea I checked the battery terminals and made sure everything was tight. But i am thinking the same thing its got to be some type of relay or loose wire or something.. thanks again! Im going to prod around today after work a little.. hopefully i find something obvious Quote Link to comment Share on other sites More sharing options...
FordService Posted April 8, 2015 Report Share Posted April 8, 2015 On 4/8/2015 at 6:02 PM, danib1227 said: It reads correct temperature then changes to 46 degrees.. then normal.. then back to 46 degrees. but Yea I checked the battery terminals and made sure everything was tight. But i am thinking the same thing its got to be some type of relay or loose wire or something.. thanks again! Im going to prod around today after work a little.. hopefully i find something obvious Hey danib1227, Have you had a chance to speak with your Ford Dealer about the concern you're experiencing? What's the current mileage on your Edge? Nick Quote Link to comment Share on other sites More sharing options...
Chrislovesfords Posted June 6, 2016 Report Share Posted June 6, 2016 I have this same issue. Anybody know where to look to resolve this issue? Quote Link to comment Share on other sites More sharing options...
DRbillZ Posted June 6, 2016 Report Share Posted June 6, 2016 (edited) Is the vent simply blowing on the inside auto sensor? Edited June 6, 2016 by DRbillZ Quote Link to comment Share on other sites More sharing options...
Chrislovesfords Posted June 6, 2016 Report Share Posted June 6, 2016 My Symptoms are exactly the same as the first post. The outside temp sensor will read and then go blank with --- and the fan will cut out at that exact time and then cycle back on. I think replacing the outside temp sensor is my first step however this fix has not helped most people and don't want to throw parts at this thing Quote Link to comment Share on other sites More sharing options...
Gbczyk84 Posted June 6, 2016 Report Share Posted June 6, 2016 For what it's worth, my 2011 had an issue of bowing cold air when you wanted heat, had to set temp to at least 75° to get warm Air. Dealer said it needed an update, no issues since that was done. May want to start there before buying parts. Quote Link to comment Share on other sites More sharing options...
Gbczyk84 Posted June 6, 2016 Report Share Posted June 6, 2016 (edited) Duplicate Edited June 6, 2016 by Gbczyk84 Quote Link to comment Share on other sites More sharing options...
Chrislovesfords Posted June 6, 2016 Report Share Posted June 6, 2016 Does ford charge for these software updates? Quote Link to comment Share on other sites More sharing options...
akirby Posted June 6, 2016 Report Share Posted June 6, 2016 On 6/6/2016 at 7:16 PM, Chrislovesfords said: Does ford charge for these software updates? Same as a repair - if you're under warranty it's free otherwise you have to pay for it. In the case of a software update it's just labor. Quote Link to comment Share on other sites More sharing options...
Chrislovesfords Posted June 6, 2016 Report Share Posted June 6, 2016 Is it normal for Ford to charge $260 for this? I don't understand why this happened when it was working fine a couple days ago Quote Link to comment Share on other sites More sharing options...
akirby Posted June 7, 2016 Report Share Posted June 7, 2016 Ford doesn't charge anything. The dealer charges whatever they want to charge so shop around. Quote Link to comment Share on other sites More sharing options...
luvford Posted June 21, 2016 Report Share Posted June 21, 2016 I talked to customer service when I was having issues, not this specific one, and they sent me a jump drive with the update. 1 Quote Link to comment Share on other sites More sharing options...
Kram0624 Posted August 24, 2019 Report Share Posted August 24, 2019 I'm having the same problem as 1st post. i replaced the Ambient Temperature Sensor and still having the problem. TIA Mark Quote Link to comment Share on other sites More sharing options...
