sarflipped Posted April 7, 2015 Report Share Posted April 7, 2015 Does anyone know if the 2011 tires will fit onto the new 2015 rims? I have winter tires with low mileage on them and would be great if they fit onto the new edge I ordered which also has 20inch rims. I heard they changed a bit so might be incompatible now which would suck as these tires are not cheap. Quote Link to comment Share on other sites More sharing options...
Chuck Yadmark Posted April 7, 2015 Report Share Posted April 7, 2015 I did a cursory measurement at the dealership and it appears to be the same bolt pattern, so I suspect so. But I too am curious about confirming this answer. Quote Link to comment Share on other sites More sharing options...
ls973800 Posted April 7, 2015 Report Share Posted April 7, 2015 (edited) I think the 2015 wheels are a new bolt pattern or other change that will not fit on the previous 2014 or older models. I believe it had been posted on the forum perhaps under the wheels and tires section. If not there, than under the 2015 discussion, perhaps a month or two ago? Edited April 7, 2015 by ls973800 Quote Link to comment Share on other sites More sharing options...
ls973800 Posted April 8, 2015 Report Share Posted April 8, 2015 (edited) Read reply's 4,5, and 6 on the following link. I had asked about the new wheels from a 2015 and this is what I found out. http://www.fordedgeforum.com/topic/15678-2015-edge-dealer-source-book-mostly-all-questions-answered-with-this/?hl=wheels&do=findComment&comment=119177 Of course this was all speculation, so actually trying to fit it on would be the definitive answer. Edited April 8, 2015 by ls973800 Quote Link to comment Share on other sites More sharing options...
cv27 Posted April 8, 2015 Report Share Posted April 8, 2015 Does anyone know if the 2011 tires will fit onto the new 2015 rims? I have winter tires with low mileage on them and would be great if they fit onto the new edge I ordered which also has 20inch rims. I heard they changed a bit so might be incompatible now which would suck as these tires are not cheap. If you're talking about the 20" wheels, then yes, they're both 245/50-20 1 Quote Link to comment Share on other sites More sharing options...
chanceone Posted July 9, 2015 Report Share Posted July 9, 2015 2015/16 edge rim bolt pattern is 108mm not 114.3mm like the 07 to 14. Quote Link to comment Share on other sites More sharing options...
