2014 Ford Edge Sport
TwinThing
Welcome! I love the"aggressive" look of the black grill with the white body color. My 2013 Limited is the same body color but with the chrome grill. Just haven't gotten around to changing the look of it yet.
I have several mods on my car that I really like. I added the DRL's from Dan at Daytime Brightlites
http://www.daytimebrightlites.com/
I also removed the factory prop rod that is used to hold up the hood and added hood struts. A much cleaner look and easier to open and lift the hood. A lot easier to work under the hood also without the prop rod in the way.
http://www.redlinetuning.com/product-p/21-11003-02.htm
I am sure you will find many other things to do with yours, and almost every thing has had a post made about it. Hope to see you around the boards.
ls973800...I too did the DRL's from Dan and last week did his HID headlights.....they are fantastic, a simple plug in install, and a perfect match for his DRL's.
They are really really bright too ....... a perfect replacemeent for the factory headlights that barely put out any light
