DunePearlEdge Posted April 6, 2015 Report Share Posted April 6, 2015 It was suggested in another thread that the stock intake silencer can be removed to gain that nice intake sound. In the link below, the top box has two large openings or connections with the intake tube, what did you use to plug these two openings? Similarly, on the smaller attached picture, there is a small tube that protrudes from the stock intake. If you removed this, how did you close the opening? http://www.fordedgeforum.com/uploads/monthly_10_2013/post-23566-0-19479500-1382221531.gif Quote Link to comment Share on other sites More sharing options...
FordMan1977 Posted April 6, 2015 Report Share Posted April 6, 2015 This topic came up awhile back and unfortuenatly I cannot find the old thread on your exact question. Anyway apparently the home improvement stores or hardware has pcv plumbing caps/plugs that can cap off those muffler holes you speak of. The old thread actually had the sizes and part#s but ill be damned if I can find it. Just be sure however you decide to plug the holes that it cannot fall into the intake tube! Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted April 6, 2015 Report Share Posted April 6, 2015 What I could find: http://www.fordedgeforum.com/topic/3477-stock-edge-exhaust-and-intake/ http://www.fordedgeforum.com/topic/13322-modified-oem-intake-box/ 3.5" plug needed: http://www.fordedgeforum.com/topic/12789-drop-in-filter-file-under-no-freakin-way/?do=findComment&comment=99116 Quote Link to comment Share on other sites More sharing options...
FordMan1977 Posted April 6, 2015 Report Share Posted April 6, 2015 Yes!!! Those are the threads! Damn your good, Lol. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted April 6, 2015 Report Share Posted April 6, 2015 LOL, I just like surfing the site! Quote Link to comment Share on other sites More sharing options...
DunePearlEdge Posted April 19, 2015 Author Report Share Posted April 19, 2015 Thank you wwwperfa-zn0w! Are both holes the same size, it looks like the rear hole is smaller. One question, I've never seen these clamps that hold on the silencer. How are they removed? I added a picture of the clamp. I am a little afraid to drive to Lowe's or Home Depot with the silencer holes open as the engine will be sucking in unfiltered air that hasn't passed the MAF sensor. Maybe it's best to take it off, measure it and then put it back on (or tape over the holes) for the drive over. Quote Link to comment Share on other sites More sharing options...
DunePearlEdge Posted May 12, 2015 Author Report Share Posted May 12, 2015 Any idea on how to remove these clamps? Quote Link to comment Share on other sites More sharing options...
wilso00000 Posted March 20, 2016 Report Share Posted March 20, 2016 Hacksaw or dikes. Hopefully you haven't been waiting for someone to post how to remove them tho Quote Link to comment Share on other sites More sharing options...
wilso00000 Posted March 20, 2016 Report Share Posted March 20, 2016 (edited) Another option would be to smooth down the holes and heat mold a sheet of abs half way around the tube and silicon it in place. That sounds like more work than necessary but it might look a little better. Just an idea Edited March 20, 2016 by wilso00000 Quote Link to comment Share on other sites More sharing options...
13EdgeSport Posted April 19, 2016 Report Share Posted April 19, 2016 (edited) Bumping with pictures. The stock clamps only need the little tooth bent back, that's holding the stock clamp on, and then it'll just fall a part. Do not over tighten the new rubber caps, just tighten till you feel some resistance. This is under $8 in parts, and less than 10 minutes time. Edited April 19, 2016 by 13EdgeSport 1 Quote Link to comment Share on other sites More sharing options...
normcloutier Posted April 19, 2016 Report Share Posted April 19, 2016 Are you just leaving the rest of the silencer off? I know it has no use once the ports are blocked but doesn't it look odd under the hood with it missing? Would be nice to somehow block the ports from the inside of the tube and be able to pop the silencer back into place. Quote Link to comment Share on other sites More sharing options...
omar302 Posted April 19, 2016 Report Share Posted April 19, 2016 13EdgeSport, what's your opinion after the mod? Sound & feel? Quote Link to comment Share on other sites More sharing options...
13EdgeSport Posted April 19, 2016 Report Share Posted April 19, 2016 I haven't noticed too much difference in sound. I recently changed my oil and did the mod. I can tell acceleration is smoother, and easier to get up to speed. I have my Afe filter coming in tomorrow, and I also ordered some black hose clamps. I'll keep you guys updated. Quote Link to comment Share on other sites More sharing options...
mcali6301 Posted April 19, 2016 Report Share Posted April 19, 2016 What is the likelihood that we could find a rubber intake tube without these holes? Quote Link to comment Share on other sites More sharing options...
13EdgeSport Posted April 19, 2016 Report Share Posted April 19, 2016 What is the likelihood that we could find a rubber intake tube without these holes? Probably really easy, but would cost more and take up more time. Wait till I get my black worm clamps and it'll look "almost" factory. Quote Link to comment Share on other sites More sharing options...
normcloutier Posted July 29, 2016 Report Share Posted July 29, 2016 Where would you get an intake tube without the holes? Alternately, anyone find a way to block the holes and reinstall the silencer? Doesn't look nice with it missing. Looks like something is missing lol Quote Link to comment Share on other sites More sharing options...
