2007 ford edge a/c climate control
Prime_official
check your drivers side actuator. Most likely it has frozen or is broken. Either way if it does not work you will have to crawl under the dash to replace it and this is not a fun thing. Verify by changing temp and looking at the drive shaft. If the shaft does not move you need to replace it.
