Scratched Brake Rotors on 2013 with 23K
The rear rotors on my 2013 have serious scratches, enough to catch your fingernail if you tried to scratch it. The fronts are still beautiful and smooth. The pads aren't even close to being worn. Wondering if anyone else has had issues with rotor wear.
What are my options? Take it up with Ford? Would this be covered under warranty? Its definitely not typical wear.
Loose pads or sticking calipers/slide pins would be my primary suspects. As far as warranty, what do you have remaining? Calipers might be covered under B2B, but not pads (wear item). Rears do sometimes get more worn than the fronts as they are used to control vehicle motion along with normal braking jobs.
Have the brakes inspected at a trusted dealership or service center, and maintenanced as needed.
