Happily decided on Edge
Xthsign
Hey folks, Ben here and I recently got 2008 Ford Edge SEL 3.5L V6 with nearly 80,000 miles on the clock. Felt the big difference over RAV4 and CRV. Just enough space for the growing kids. Aside from little fade and minor problems, she's running excellent. Been lurking for a couple of weeks now and decided to sign up so I can get as much ideas and probably ask some questions.
Welcome, Have my 07 SEL for less than a year and all I've done is put new tires on her. Started with 83,000 miles and now have 91,000.
If it's a FWD you should be fine. If it's AWD you need to watch the PTO for leaks.
I use synthetic 5 W 20 Mobile 1 and I plan on doing a trans oil change when the weather finally gets better. I also will be doing front brakes because of a warped rotor. If you do your own repairs the parts are fairly inexpensive. If you send it out you are still doing better than import repairs.
Good luck, I love this vehicle. At 80,000 miles you are just broken in. :)
