factor99 Posted March 15, 2015 Report Share Posted March 15, 2015 I need to touch up a few stone chips on my platinum white Edge. I have heard the OEM touch-up for this colour is poor so I was going to order some from Dr. ColorChip. I see now though a two part OEM paint with a basecoat and topcoat. http://www.amazon.com/Ford-Motorcraft-Platinum-Basecoat-Topcoat/dp/B00BR05EEY/ref=sr_1_1?s=automotive&ie=UTF8&qid=1426453042&sr=1-1&keywords=ford+platinum+white+touch+up+paint It has limited reviews but all the relevant ones are good. I thought the OEM that has poor results was a one step. Is it actually this 2 step or are they different products? Has anyone here used it successfully? Quote Link to comment Share on other sites More sharing options...
akirby Posted March 15, 2015 Report Share Posted March 15, 2015 I touched up a fairly large section of the rear hatch (about 4-8 sq in) using paintscratch.com aerosol (white platinum). They also have pens and other options with all 3 coats (base, mid and clear). Always had good results with their products. 2 Quote Link to comment Share on other sites More sharing options...
factor99 Posted April 14, 2015 Author Report Share Posted April 14, 2015 Thanks akirby. Both paintscratch and Dr. ColorChip look good, but since I am in Canada on only have some small chips I have just ordered the 2-part OEM touchup paint for ~Can$23 and I will see for myself how it is. I will post the results (it might be a while; I might not get it for a week and then I have to find the time use it carefully) 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted April 16, 2015 Report Share Posted April 16, 2015 (edited) I bought the UG OEM (Motorcraft) touch up. Comes in 2, 1/2 ml bottles. 9U2J-19500-LA BASE COAT, 9U2J-19500-MA TOP COAT Bottles contain both brush and roller. (Roller should be better for pin-pointing scratches). Only used it one on a small chip; worked OK, looks very close to original. After it dried, I rubbed with rubbing compound and hardly noticeable. Instructions are wrapped around the bottles. Edited April 16, 2015 by enigma-2 Quote Link to comment Share on other sites More sharing options...
factor99 Posted April 16, 2015 Author Report Share Posted April 16, 2015 Thanks enigma, that looks like one I am getting, I'm glad it looks OK, that will be better than the grey primer spot on the front of my hood... I know it will take more than just dapping it on. Quote Link to comment Share on other sites More sharing options...
