Marjieo Posted March 14, 2015 Report Share Posted March 14, 2015 hi everyone. I have a 2008 ford edge.I have 82,000 miles on the car.I think I need to change the transmission fluid.can anyone tell me if I need to remove the pan to drain the fluid and get to any filter,can anyone give me the procedure for this or site that will help Quote Link to comment Share on other sites More sharing options...
ls973800 Posted March 14, 2015 Report Share Posted March 14, 2015 Doing a search for "transmission fluid change" will give you some good results of how to do it. The filter is not replaceable unless you tear down the transmission. It is considered "lifetime" just as the fuel filter in the fuel tank is. No more changing those, either. http://www.fordedgeforum.com/topic/15702-transmission-fluid-change-edge-2009-sel/?hl=%2Btransmission+%2Bfluid Quote Link to comment Share on other sites More sharing options...
akirby Posted March 14, 2015 Report Share Posted March 14, 2015 If the transmission filter is clogged the tranny is already toast. Better to use the cooler lines to swap out virtually all of the fluid. Quote Link to comment Share on other sites More sharing options...
