Overheating, no heat from vents.
briandye
She's home!
I am so thankful yet so mortified. Thankful obviously because I don't need a water pump, mortified because this is a simple case of could-have-been-avoided-had-I-paid-more-attention.
I obviously took way more coolant out than I put in back when I "changed" the coolant. I also seemed to somehow skip over the part in your post that said "wait until engine completely cools down, add more coolant if needed, then start and run on high heat."
I blame part of that on the frustration I had that day, still being -10 with the windchill and no patience.
Thank you so much WWWPerf. Can I buy you a case of beer or something? (Or beverage of your choice?) lol you've been such a great help through these few issues I've had with my Edge.
I'm just gonna go drop the money probably at the Ford dealer for a complete flush and fill with new/correctly mixed coolant. I used my tester and with the G05/water mix I added to fill up, it says I'm protected as far as it would show (Something like -64) so the mix is probably a bit off. (Though freeze protection to -64 is ideal for this damn weather we've been having!)
One more thing I noticed, I think my cap is a 16 PSI cap and the coolant jug/tester say based on 15 PSI, does that 1 PSI make a difference? I might be wrong and actually have a 15, but I swear it said somehing else. I'll have to check tomorrow again.
And does the coolant have to be completely cool to test it? Mine was warm, I read online it does matter and doesn't matter. About a 50/50 answer with that one. Just overthinking probably, but after my mess up, I don't think that's so bad to overthink these kinds of things right now, lol.
I looked over pics of the degas bottle cap and it does say 110 KPa or 16 psi on mine as well. I don't think you need to worry about that minor difference. Testing it warm, say around 70F but definitely at/above 32F is best, does your tester give you a chart? Specs are usually laid out at a specific testing temperature. Specific gravity is actually what is being tested for, and it tells you the % of coolant in the solution. It does NOT tell you anything about any other properties such as rust/corrosion inhibition. You might be able to guess at it with a voltmeter (electrolysis; readings also sensitive to temperature) and pH strips.
http://www.engineeringtoolbox.com/water-temperature-specific-gravity-d_1179.html
http://www.engineeringtoolbox.com/ethylene-glycol-d_146.html
As to how pressure affects the coolant solution/any aqueous solution:
http://www.animations.physics.unsw.edu.au/jw/freezing-point-depression-boiling-point-elevation.htm
Fun facts on the different coolant formulations:
https://www.youtube.com/watch?v=Ffpe8aVvb2c
2 more questions :)
1. Does windchill come into play with antifreeze? Like if it's -10 outside but "Real Feel" is -40, and my coolant was only rated to -35, should I worry? (Theoretically speaking, with random numbers of course)
2. How does one regain trust from their vehicle? What can I have her do to make me trust her again? (lol just playing) but it's seriously gonna take me a few long trips before I feel safe driving it again
  • 4 weeks later...
A nightmare of a topic, and likely and a very possible future event.
I am running a larger water pump pulley on my 2000 grand prix 3800 GTX. Car has
over 111K miles. Temps are really controlled, due to Royal Purple and Lucas synthetic stabilizer.
A Pontiac mechanic told me that he has seen water pumps last well over 200K miles.
I am certain that it would be a miserable job having to replace the water pump on a 3.5L Edge. Why not just install
performance cams why you are pulling your **** with all the work required?...yeah right..cheers
Ended up just finding out that when i flushed the coolant, I somehow replaced way less than I drained out. Lesson learned the hard way.
I blame it on the pressurized system or whatever the Edge has. Done a million drain (or flush) and refills of coolant on previous vehicles and never had an issue. They all had a radiator cap though and burping the air out was as simple as just starting the engine with the cap off and topping off as neccesary.
Most newer cars have a separate bleed valve or screw higher than the radiator.
Does Ford have this in any of their late model vehicles? Haven't seen any, and the FSM's say you need a "system" to properly bleed the coolant of air. Hence the approach of running the heat at full blast, driving for some time at engine operating temperature, and refilling the degas/overflow bottle to the fill line with engine at ambient, multiple times as needed.
It does appear to be a feature on the Fusion/Milan/MKZ, at least on some engines:
http://www.autozone.com/repairguides/Ford-Fusion-Milan-MKZ-2008-2009/Maintenance/Coolant/_/P-0996b43f80eb9c7a
I see a heater bleed valve fitting for the LS:
http://www.justanswer.com/ford-lincoln/3o8cx-trying-bleed-air-cooling-system.html
Ford Escape with the 3.0L V6:
http://www.fordmanuals.org/page-3545.html
#7 in this pic
Edited by WWWPerfA_ZN0W
Hmmmm that's what I thought, my UG is showing up to 213 degrees as the "Engine Temp" (don't know if there's a difference, but I believe it also has a coolant temp, but I didn't have it set to show when I was playing with it)
This was while moving too. It was around 192 when I started (already warm) and idled for about 5 minutes then drove the course of my neighborhood and about a mile down the main road doing 45 or so and it continued to go up to said temp, didn't drop, didn't surge just a slow rise then I got back home and went in.
Dash gauge showed normal, halfway up.
Yeah I'm getting readings as high as 220. It was a short 4~ mile drive but it was still warm from just a little bit ago. Gets between 210-220 and doesn't fluctuate much. Seems to drop a little when I let off the gas and coast to a stop like a stoplight or something.
My needle doesn't ever leave the middle of the gauge (once it's warmed up)
In the video im uploading to show the UG, I am driving primarily without heat on, cruise set at 45, and to see if there's a difference, I turn the heat on at one point, and once I'm in my driveway at the end, idling, I even crank the AC. At the end when I shut it off, you can hear that the electric fan(s?) were roaring like I asked about in another thread.
BTW- Coolant temp shows up as "engine temp" there aren't two separate ones. Also, if it matters, it's about 47 degrees outside. Will share the youtube link when it's done uploading.
Edited by briandye
