allport Posted February 9, 2015 Report Share Posted February 9, 2015 Does anyone know if you can call ford and give them your vin to see if there are any outstanding flashes for you car? I noticed the trans is super soft shifting but never slips. Also gets a little temperamental when gearing down while rolling and no throttle applied. It all feels like ecu/tcm related to me and not physically broken Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted February 9, 2015 Report Share Posted February 9, 2015 Pretty sure you would have to take it in to a dealership, they may not charge for the lookup though. They will need to hookup the Edge to IDS to determine what PCM software version is loaded. Quote Link to comment Share on other sites More sharing options...
macbwt Posted March 8, 2015 Report Share Posted March 8, 2015 How many miles on it and have you ever had the rear output sensor replaced. Sure sounds like that sensor is starting to go south. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted March 8, 2015 Report Share Posted March 8, 2015 On 3/8/2015 at 6:30 PM, macbwt said: How many miles on it and have you ever had the rear output sensor replaced. Sure sounds like that sensor is starting to go south. And depending on the dealership, you may have a lot of convincing to do if they don't see codes set in memory. TSS/OSS sensor replacement (should be done at the same time) often fixes shudders, sometimes slippages in the transmission. Quote Link to comment Share on other sites More sharing options...
allport Posted March 8, 2015 Author Report Share Posted March 8, 2015 So shudder at all. No codes either. Only one I get is 1248 and I think that's steering wheel sensor. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted March 9, 2015 Report Share Posted March 9, 2015 How many miles on the Edge? A trans fluid drain/fill might take care of it. Quote Link to comment Share on other sites More sharing options...
allport Posted March 9, 2015 Author Report Share Posted March 9, 2015 125,000km just had ptu inner and outer seal done. Seems to be worse after that too. Considering another drain. And fill soon. Quote Link to comment Share on other sites More sharing options...
macbwt Posted March 9, 2015 Report Share Posted March 9, 2015 I would drive my Edge on roads that were hills and when I went down the hill not much happened but when the engine started to climb the tranny would jerk ever so slightly over time. The longer this went on the harder the jerk would be when it down shifted to climb the hill while using cruise control. I could lessen the shift force slightly by driving without cruise control. In city driving it would upshift and jerk. This went on for say about 1k or 2k then finally the rear output sensor failed. Your discription sure sounds the same as I did not get even one single code until it failed completely. Since you never replaced yours I am betting it needs to be changed/replaced. Thing is the dealer will not beable to say this is the problem until it fails. 700-800 dollars to repair. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted March 9, 2015 Report Share Posted March 9, 2015 (edited) The sensors themselves are not that expensive, but if you can find a service shop or are mechanically inclined, the labor costs should be much less. There's no whizbang step that is required in the R&R process. Edited March 9, 2015 by WWWPerfA_ZN0W 1 Quote Link to comment Share on other sites More sharing options...
macbwt Posted March 9, 2015 Report Share Posted March 9, 2015 Back then I was obviously leary of working on the trans. Today I would tear into it (and Pray) fix it myself after a few visual aids and having the lift available everything is now easier. On 3/9/2015 at 2:22 PM, WWWPerfA_ZN0W said: The sensors themselves are not that expensive, but if you can find a service shop or are mechanically inclined, the labor costs should be much less. There's no whizbang step that is required in the R&R process. Quote Link to comment Share on other sites More sharing options...
