fishx65 Posted February 3, 2015 Report Share Posted February 3, 2015 I'm probably one of the few that have an Edge without sync/bluetooth. Been researching the aftermarket for a while now and finally decided on the Kinivo BTC450. Since my 2011 has a 3.5mm aux jack in the center console, I figured the Kinivo would be perfect. This little unit is really nice with awesome voice and music streaming quality. It's also very unobtrusive and easy to install. Only problem I'm having is that it will not pair automatically each time I reenter my vehicle. At first I thought it was defective but then figured out the problem. Fords have constant power to the power ports which keeps the Kinivo on at all times. It needs to cycle on and off with the vehicle to automatically pair. To remedy this I just need to hard wire it to a switched power source when I get a chance. So I guess the point of this post is that, if ya don't have sync, there are some good options out there that work really well. Quote Link to comment Share on other sites More sharing options...
akirby Posted February 3, 2015 Report Share Posted February 3, 2015 I thought Sync was standard on SELs? You don't have usb ports inside the center console? Quote Link to comment Share on other sites More sharing options...
fishx65 Posted February 3, 2015 Author Report Share Posted February 3, 2015 You would think it would have been standard!!!! No sync or USB ports in my 11 SEL. Quote Link to comment Share on other sites More sharing options...
akirby Posted February 3, 2015 Report Share Posted February 3, 2015 Strange........ Quote Link to comment Share on other sites More sharing options...
