AZDiddy Posted February 2, 2015 Report Share Posted February 2, 2015 Just purchased a 2013 Edge. The bluetooth is connected to my iPhone and works for phone calls but I can't play any songs from iTunes or other music apps. Confused. The Ford user guides aren't very helpful. What am I doing wrong? Quote Link to comment Share on other sites More sharing options...
AZDiddy Posted February 2, 2015 Author Report Share Posted February 2, 2015 The songs are playing on my phone but no sound is coming out. Quote Link to comment Share on other sites More sharing options...
akirby Posted February 2, 2015 Report Share Posted February 2, 2015 Did you switch the audio input to the BT device? Make sure the iphone audio source is set to sync. Quote Link to comment Share on other sites More sharing options...
AZDiddy Posted February 2, 2015 Author Report Share Posted February 2, 2015 Thank you! I just went out and sat in the car and played with all of the buttons until I finally found how to choose the source and set it to BT. Quote Link to comment Share on other sites More sharing options...
AZDiddy Posted February 4, 2015 Author Report Share Posted February 4, 2015 Can I save that setting so I don't have to change it every time? I prefer to use the bluetooth. Quote Link to comment Share on other sites More sharing options...
bce Posted February 6, 2015 Report Share Posted February 6, 2015 On 2/4/2015 at 3:58 PM, AZDiddy said: Can I save that setting so I don't have to change it every time? I prefer to use the bluetooth. Not sure what setting you are talking about, but if you have the audio source set to bluetooth when you turn it off, it will be the same source the next time you start your car. Quote Link to comment Share on other sites More sharing options...
AZDiddy Posted April 17, 2015 Author Report Share Posted April 17, 2015 Sometimes it stays there when I turn it back on again but it doesn't sync up - I have to go through the steps again when I turn the car back on. Quote Link to comment Share on other sites More sharing options...
akirby Posted April 17, 2015 Report Share Posted April 17, 2015 Do you have that phone set to Favorite? Does it not connect at all or does it connect to a different device? Quote Link to comment Share on other sites More sharing options...
FordIVTteam Posted April 22, 2015 Report Share Posted April 22, 2015 Which SYNC system do you have, AZDiddy? Here's a link to help you determine which one (just in case): http://owner.ford.com/how-tos/sync-technology/all/get-started-with-sync/how-to-identify-your-sync-version.html Fun fact - with all of our systems, you can press the VOICE button on your steering wheel and say BLUETOOTH AUDIO to access that source. Rebecca Quote Link to comment Share on other sites More sharing options...
