Ford recalls SUVs because drivers are accidentally turning them off
Libra1224
http://money.cnn.com/2015/01/06/autos/ford-push-button-ignition-recall/index.html
Ford is recalling about 13,500 2015 Lincoln MKC because drivers are shutting the vehicle off by mistake.
Drivers are mistakenly touching the crossover SUV's push-button ignition button while the car is driving, Ford found.
The MKC has buttons to put the car in different gears, rather than a traditional gear shift. But drivers who are reaching for the "S" button to put the car in sport mode are sometimes hitting the adjacent start-stop button.
Doesn't the Ford/Lincoln keyless ignition have the same safeguard that had supposed runaway Toyota owners claiming the car wouldn't shut off? When in park or neutral, it only takes a press of the start/stop button. But when in gear you should have to push and hold the button for three seconds or more to make it shut off. That was implemented to avoid exactly this kind of issue but many Toyota owners didn't know so they kept stabbing at the button with no effect. Of course, shifting to neutral would have made the car slow down (so would pressing the brake instead of the accelerator) but hey, their Toyota owners. ;)
