ford edge wont go forward,reverse not even neutral
W714icked
so i was going to the store today and about 50 feet from my house my edge stop it display a message saying break system failure for like a second and than went away and wouldn't go forward so I tried to back it up and noting, put it on neutral to try to push it and would not move i turn it off and back on i finally got it to move but real slow and making a terrible sound like metal grinding any help would be greatly appreciated
ford edge 2007 AWD
Hard to say what the cause might be, but I'd check the brakes (calipers, rotors, pads) first. The calipers on the rear are known to seize, and that would cause the pad to grind against the rotor continuously. Also check for any brake fluid at the lines going into the caliper. Does the fluid in the master cylinder reservoir look clean/full?
Other possibilities relating to brakes are wheel speed sensors and ABS components.
