Kim Barber Foss Posted December 11, 2014 Report Share Posted December 11, 2014 I have a 2008 edge limited I purchased in May and now have the darndest thing happen with my liftgate. The first issue was when I would use any button to open the liftgate it would open, ding 3 times and then start to automatically close. It wouldn't do this all the time, but frequently. I read to try to reset it by opening and then closing manually. This would periodically work, but it always happened again. Now, however, the power feature is not working at all. Power liftgate is "on" from the instrument panel. When I push any of the buttons it "clicks" like it is enagaging but it never opens. I have to open it manually and it has a lot of resistance. Once manually opened it will not stay open it wants to fall back closed right away. My head has been in the way several times so needless to say I want to get this issue resolved ASAP. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 11, 2014 Report Share Posted December 11, 2014 Weak liftgate struts? That would be my first guess. I know on the manual liftgate (mine has that), the struts are not very strong, and it gets worse in colder weather. 1 Quote Link to comment Share on other sites More sharing options...
Kim Barber Foss Posted December 11, 2014 Author Report Share Posted December 11, 2014 would the struts make it not automatically open? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 11, 2014 Report Share Posted December 11, 2014 If the struts have become too weak, it is possible. Quote Link to comment Share on other sites More sharing options...
CinnamonEdge Posted December 11, 2014 Report Share Posted December 11, 2014 I think that the struts do most of the opening when it comes to the automated liftgate. Even if you open the liftgate without power it should support itself. good luck. Quote Link to comment Share on other sites More sharing options...
Kim Barber Foss Posted December 11, 2014 Author Report Share Posted December 11, 2014 On 12/11/2014 at 7:09 PM, CinnamonEdge said: I think that the struts do most of the opening when it comes to the automated liftgate. Even if you open the liftgate without power it should support itself. good luck. Yeah right now it's like openning a cement door and it falls right back down on itself Quote Link to comment Share on other sites More sharing options...
CinnamonEdge Posted December 11, 2014 Report Share Posted December 11, 2014 Take a trip to the auto store. and get some new struts because even if the power liftgate mechanism is failing you will still need new struts. 1 Quote Link to comment Share on other sites More sharing options...
DKS Posted December 18, 2014 Report Share Posted December 18, 2014 My 2008 was purchased in 2010 and from the beginning in colder weather the hatch would go up and then go down by itself. It was much worse earlier this winter. I ordered new struts from Amazon.com, installed them in 10 minutes and fixed the issue. Change your hatch lifts and solve your issue. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 18, 2014 Report Share Posted December 18, 2014 (edited) I bought mine off EBay a year and a half ago (manual liftgate). They started acting up again this year once the colder weather set in. I think I have a 2 year warranty limited lifetime warranty from the seller, let's see how a return/replacement goes http://www.ebay.com/itm/370924078321 Edited December 18, 2014 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
Kim Barber Foss Posted December 30, 2014 Author Report Share Posted December 30, 2014 I purchased and installed new struts (was super easy thanks!) Is there something I have to do now to reset the power mechanism? When I push any of the liftgate buttons I hear it click to start, but then nothing happens Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 30, 2014 Report Share Posted December 30, 2014 (edited) With any luck, it should only need the initialization sequence as below. Power Liftgate Initialization NOTE: If the power liftgate system is turned OFF in the message center, the system cannot be activated with any switches or with the liftgate handle. The system will need to be turned ON for any power operation to occur. NOTE: The power liftgate may not operate under the following conditions: A low voltage or dead battery A disconnected battery If any of these conditions has occurred, the power liftgate must be reset. Manually close and fully latch the power liftgate. NOTE: If the power liftgate does not open during this step, refer to the symptom chart to diagnose the power liftgate for no operation. Power open the power liftgate by using the key fob or control switch.Once the power liftgate is fully open, close the power liftgate by using the key fob or control switch. Edited December 30, 2014 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
Kim Barber Foss Posted December 30, 2014 Author Report Share Posted December 30, 2014 what is the initialization sequence? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 30, 2014 Report Share Posted December 30, 2014 Steps 1-3 in my previous post. You may have done this already, but try it anyway. Quote Link to comment Share on other sites More sharing options...
Kim Barber Foss Posted December 30, 2014 Author Report Share Posted December 30, 2014 Seems like something is missing between steps 1 and 2 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted January 5, 2015 Report Share Posted January 5, 2015 Here's what I have in my 09 mkx service manual: Power Liftgate InitializationNOTE: The power liftgate may not operate correctly under the following conditions: A low voltage or dead batteryA disconnected batteryRepairs/adjustments have been made to the power liftgate rod, power liftgate motor, liftgate hinges or liftgate strikerIf any of these conditions has occurred, the power liftgate must be reinitialized. NOTE: Battery power must be removed from the Liftgate/Trunk Module (LTM) for 20 seconds before the LTM will enter the initialization mode. Disconnect the battery or remove the LTM fuse(s).Wait 20 seconds and reconnect the battery or reinstall the LTM fuse(s).If liftgate is not already in the fully closed position, manually close and fully latch the power liftgate.NOTE: Make sure the power liftgate system is turned ON in the message center before performing this step. NOTE: If the power liftgate does not open during this step, refer to the Symptom Chart to diagnose the inoperative power liftgate. Power open the power liftgate by using the key fob or control switch.Once the power liftgate is fully open, close the power liftgate by using the key fob or control switch. Quote Link to comment Share on other sites More sharing options...
kellim Posted January 28, 2015 Report Share Posted January 28, 2015 same problem, 08 edge limited day one, tailgate worked great. day two, tailgate goes up, couple seconds later comes down. day three, tailgate unlatches and latches but makes no attempt to go up or down??? Quote Link to comment Share on other sites More sharing options...
akirby Posted January 28, 2015 Report Share Posted January 28, 2015 On 1/28/2015 at 3:01 PM, kellim said: same problem, 08 edge limited day one, tailgate worked great. day two, tailgate goes up, couple seconds later comes down. day three, tailgate unlatches and latches but makes no attempt to go up or down??? Did you replace the struts? Quote Link to comment Share on other sites More sharing options...
kellim Posted January 28, 2015 Report Share Posted January 28, 2015 not yet. at work. all I remember seeing is the main mech rod. are there door struts too? Quote Link to comment Share on other sites More sharing options...
akirby Posted January 28, 2015 Report Share Posted January 28, 2015 Forgot if it's one or two but that sounds like the problem as described above. If the strut fails the motor can't lift the door. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 7, 2015 Report Share Posted July 7, 2015 Any resolution to this problem, Kim or kellim? Here is a TSB on a similar problem with the Explorer: 12-2-6 POWER LIFTGATE DOES NOT OPEN OR REVERSES AFTER OPENING APPROXIMATELY 25 MM (1 INCH) Publication Date: February 10, 2012FORD: 2012 ExplorerISSUE:Some 2012 Explorers vehicles equipped with the power liftgate may not open or open approximately 25 mm (1 inch) then reverse when using the power open feature.ACTION:Follow the Service Procedure steps to correct the condition.SERVICE PROCEDURERemove the liftgate striker bolts and striker.Discard striker.Install the new liftgate striker.Torque striker bolts to 22 N-m (16 lb-ft).PART NUMBER PART NAMEBB5Z-7843252-A StrikerWARRANTY STATUS:Eligible Under Provisions Of New Vehicle Limited Warranty CoverageIMPORTANT: Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.OPERATION DESCRIPTION TIME120206A 2012 Explorer: Replace The Liftgate Striker (Do Not Use With Any Other Labor Operations) 0.2 Hr.DEALER CODINGBASIC PART NO. CONDITION CODE7843252 16PROGRAM CODET11 Quote Link to comment Share on other sites More sharing options...
viera2647 Posted December 17, 2019 Report Share Posted December 17, 2019 I have a 2008 Ford Edge purchased new, only has 54,000 miles on it. My lift gate is totally unoperational Prior to this it began shutting on its own striking me in the head and by reflex I shoved it open trying to step away from it before I could do this it came down again fast and caught my neck and shoulder. This is not just a mechanical or electrical problem, it is a dangerous hazard. Quote Link to comment Share on other sites More sharing options...
akirby Posted December 17, 2019 Report Share Posted December 17, 2019 Are you sure the strut isn't just worn out? 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 18, 2019 Report Share Posted December 18, 2019 It's almost 2020 now. Time to replace the struts, I think. Go with Motorcraft or Sachs Stabilus. Quote Link to comment Share on other sites More sharing options...
viera2647 Posted December 18, 2019 Report Share Posted December 18, 2019 Might be 2020, but my 2008 only has 54,000 miles. This Ltd. edition has had so many recalls. FORD - once again Fix or repair daily !!! I just looked at the total sale price for this in 2008, it was $40,006.16 and this was a dealers demo with a 1000 miles on the odometer. In retrospect, I should have had my head examined. I have had Fords my entire life, including Lincoln, Thunderbird, 2 Mustangs, Ford Explorer ............. NO MORE FORDS FOR ME> Quote Link to comment Share on other sites More sharing options...
jmr061 Posted December 18, 2019 Report Share Posted December 18, 2019 Liftgate struts don't last forever. That's a fact of life and vehicles. Doesn't matter if its a $100,000 vehicle or how many miles are on it. I don't think you will get any sympathy here but perhaps you feel better having vented. 1 1 Quote Link to comment Share on other sites More sharing options...
