ezflyr Posted December 2, 2014 Report Share Posted December 2, 2014 Hi All, i recently downloaded the Gen1-3.1 Sync update for my 2010 Ford Edge. I've put the update file on a USB thumb drive and I'm ready to update my system. Unfortunately, non of the methods I've found to actually initiate the update seem applicable to my very basic non-navigation equipped SYNC system. Simply inserting the USB drive into the USB port has no effect! How do i get SYNC to start an update from the USB drive on my system? Thanks, John Quote Link to comment Share on other sites More sharing options...
akirby Posted December 2, 2014 Report Share Posted December 2, 2014 first guess is it's not recognizing the files on the usb drive. Reformat it as fat32 so it erases everything and re-download it just to be safe. If it still does it try disconnecting and reconnecting the negative battery cable to reset everything and try it again. Quote Link to comment Share on other sites More sharing options...
FordIVTteam Posted December 3, 2014 Report Share Posted December 3, 2014 Hi All, i recently downloaded the Gen1-3.1 Sync update for my 2010 Ford Edge. I've put the update file on a USB thumb drive and I'm ready to update my system. Unfortunately, non of the methods I've found to actually initiate the update seem applicable to my very basic non-navigation equipped SYNC system. Simply inserting the USB drive into the USB port has no effect! How do i get SYNC to start an update from the USB drive on my system? Thanks, John Hi John, Like akirby mentioned, the thumb drive must be formatted as FAT32. Also keep in mind that the update will not work if the USB has U3 encryption or is password protected. Let me know which type of computer you're using if you need assistance formatting the USB to FAT32. Once you've verified that the USB is set up correctly, follow these instructions to download the update: http://support.ford.com/sync-technology/download-software-updates-sync Kim Quote Link to comment Share on other sites More sharing options...
