edp428 Posted November 28, 2014 Report Share Posted November 28, 2014 Recently I had a remote starter installed in my 2013 Edge Limited. Due to the dealerships limited choices series 100 was installed. I'm a bit unhappy with this product as it does not turn on the heated seats and I cannot figure out how to leave the it running when exit the vehicle and turn off the ignition. My previous car was a 2012 Fusion and the remote started allowed me to hold the button before I exited the vehicle, remove the key and it would continue to run. Does anyone know if this can be done and if so, how? Quote Link to comment Share on other sites More sharing options...
omar302 Posted November 29, 2014 Report Share Posted November 29, 2014 There should be a menu for remote start in the cluster settings menu. One of the options is for the driver & passenger seats & you should be able to select Auto or off. In Auto, the vehicle would decide if the heated seats are required to be turned on depending on outside climate temperature. Quote Link to comment Share on other sites More sharing options...
