SIPOFA Posted December 13, 2007 Report Share Posted December 13, 2007 Hello guys, I am fitting a MKX engine cover on my Edge and wanted to know the Length of your MKX oil cap. When I put the rubber in the hole and try to screw the Edge oil cap it doesn't fit. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
Good_Hands Posted December 13, 2007 Report Share Posted December 13, 2007 SIPOFA said: Hello guys, I am fitting a MKX engine cover on my Edge and wanted to know the Length of your MKX oil cap. When I put the rubber in the hole and try to screw the Edge oil cap it doesn't fit. Thanks for the help. I'm really sorry but... I just can't help but laugh when I read this. Bad. I know. Quote Link to comment Share on other sites More sharing options...
Abrannan19 Posted December 13, 2007 Report Share Posted December 13, 2007 that is funny.. why didnt you just buy an MKX? Quote Link to comment Share on other sites More sharing options...
SIPOFA Posted December 13, 2007 Author Report Share Posted December 13, 2007 Age guys, age. I aint old enough to have a Lincoln or a Buick. I like the sporty edge. And, whats funny about modding my Edge anyway??? Quote Link to comment Share on other sites More sharing options...
Good_Hands Posted December 13, 2007 Report Share Posted December 13, 2007 SIPOFA said: Age guys, age. I aint old enough to have a Lincoln or a Buick. I like the sporty edge. And, whats funny about modding my Edge anyway??? I wasn't laughing at the fact you want to mod your Edge. I have Enkei wheels and Hankook 20's on mine so... I was laughing at the way you worded your post. My mind was a bit in the gutter when I read it and found some of your statements amusing SIPOFA said: Hello guys, I am fitting a MKX engine cover on my Edge and wanted to know the Length of your MKX oil cap. When I put the rubber in the hole and try to screw the Edge oil cap it doesn't fit. Thanks for the help. Double entende' city. High school bathroom humor...I know. Quote Link to comment Share on other sites More sharing options...
Grey Posted December 13, 2007 Report Share Posted December 13, 2007 The 710 cap - oops turn it over -----OIL cap is 1 1/2 Inches deep - same as on the Edge. The MKX has a 3 1/8" long plastic sleeve that goes doen into the valve cover that the OIL cap screws into. I believe that this sleeve (and foam rubber gasket) is what you will need to install the cover and use your existing cap. I do not know if the valve cover is different - that would be a major swap out. Hopefully the sleeve screws into the valve cover and the cap screws into it. I presume the rubber gasket around the sleeve at the top keeps the cover from making noise. Quote Link to comment Share on other sites More sharing options...
npggirl Posted December 13, 2007 Report Share Posted December 13, 2007 It isn't just you. When I first read the post, I thought of this guy: Quote Link to comment Share on other sites More sharing options...
SIPOFA Posted December 14, 2007 Author Report Share Posted December 14, 2007 Hello guys, thanks for the help. I have everything but sleeve. Should fit no problem. I will post pics when done. Quote Link to comment Share on other sites More sharing options...
SIPOFA Posted December 14, 2007 Author Report Share Posted December 14, 2007 Hello guys, forgot to mention, if you want to do this you will need : Engine cover from MKX, rubber for oil cap, 5mm nut on bottom RH side of valve cover (this holds the edge of cover in grommet that it comes with), and the sleeve so you can put your oil cap!!!!! Quote Link to comment Share on other sites More sharing options...
DJ Starr Posted December 15, 2007 Report Share Posted December 15, 2007 Trainmaster said: Pardon my ignorance, but, why do you want an MKX engine cover on the engine of an Edge? What does this accomplish? Does it make the engine perform better? Maybe it fools the engine compartment into thinking it is in a Lincoln?? Are you going to change the grill, tail lights, lettering, and all that other stuff too??? What does age have to do with whether you own a Lincoln, Buick or whatever??Just curious. Sound Dampening? Let us know please, I am curious as well.... Quote Link to comment Share on other sites More sharing options...
SIPOFA Posted December 17, 2007 Author Report Share Posted December 17, 2007 Hello guys, yes sound dampening is one reason, mostly beacause I like the engine being covered. And i can install a polished aluminum plate over where it says Lincoln from my work, costs me nothing. Quote Link to comment Share on other sites More sharing options...
