Edgieguy Posted December 4, 2007 Report Share Posted December 4, 2007 If you didn't get Cargo Management as an option $65. And you dont want to pay $250 from Ford Parts, an easy fix is to make it yourself. This is what I did with a friends Edge. I really should have taken pictures throughout the project to make a "how to" but failed to in my rush to just get it done. Here's a quick write up. 1. Pry the foam insert from the rear of the vehicle. Its easier to work on it on a bench or table. 2. Gently cut out the Styrofoam honeycomb that takes up the inside of the rear tire surround. DO NOT CUT THE OUTSIDE WALLS, ONLY THE INSIDE. 3. With some medium and then fine grit sandpaper, sand smooth all the places you cut out the styrofoam honeycomb. 4. At this point you have three options for finishing off your new cargo organizer. You can: A. spray it with paint to seal the foam. B. Fill it with a light coat of Bondo body filler, sand it smooth and paint it for a cleaner look. C. Fiberglass it, sand it, and then paint it to match your body color. (You can use cans of DupliColor and Clear you don't need to take it to a body shop) Sorry I didn't take photos when we did it. I can tell you it came out great! Im planning on doing it to mine when I eventually get one. Ill post pictures the next time. PROMISE! Quote Link to comment Share on other sites More sharing options...
07 MKX Posted December 4, 2007 Report Share Posted December 4, 2007 This would look t ts if it was chromed! Quote Link to comment Share on other sites More sharing options...
npggirl Posted December 4, 2007 Report Share Posted December 4, 2007 This would look t ts if it was chromed! Hey! 07...You must not have gotten the memo.... the word "tits" is childish and old.... *grins* Please...carry on! Quote Link to comment Share on other sites More sharing options...
npggirl Posted December 4, 2007 Report Share Posted December 4, 2007 If you didn't get Cargo Management as an option $65. And you dont want to pay $250 from Ford Parts, an easy fix is to make it yourself. This is what I did with a friends Edge. I really should have taken pictures throughout the project to make a "how to" but failed to in my rush to just get it done. Here's a quick write up. 1. Pry the foam insert from the rear of the vehicle. Its easier to work on it on a bench or table. 2. Gently cut out the Styrofoam honeycomb that takes up the inside of the rear tire surround. DO NOT CUT THE OUTSIDE WALLS, ONLY THE INSIDE. 3. With some medium and then fine grit sandpaper, sand smooth all the places you cut out the styrofoam honeycomb. 4. At this point you have three options for finishing off your new cargo organizer. You can: A. spray it with paint to seal the foam. B. Fill it with a light coat of Bondo body filler, sand it smooth and paint it for a cleaner look. C. Fiberglass it, sand it, and then paint it to match your body color. (You can use cans of DupliColor and Clear you don't need to take it to a body shop) Sorry I didn't take photos when we did it. I can tell you it came out great! Im planning on doing it to mine when I eventually get one. Ill post pictures the next time. PROMISE! Pretty sharp idea! Quote Link to comment Share on other sites More sharing options...
Good_Hands Posted December 4, 2007 Report Share Posted December 4, 2007 Pretty sharp idea! I think that idea is the ears! (since tits is so childish) Quote Link to comment Share on other sites More sharing options...
KewlRobD Posted September 29, 2008 Report Share Posted September 29, 2008 If you didn't get Cargo Management as an option $65. And you dont want to pay $250 from Ford Parts, an easy fix is to make it yourself. This is what I did with a friends Edge. I really should have taken pictures throughout the project to make a "how to" but failed to in my rush to just get it done. Here's a quick write up. 1. Pry the foam insert from the rear of the vehicle. Its easier to work on it on a bench or table. 2. Gently cut out the Styrofoam honeycomb that takes up the inside of the rear tire surround. DO NOT CUT THE OUTSIDE WALLS, ONLY THE INSIDE. 3. With some medium and then fine grit sandpaper, sand smooth all the places you cut out the styrofoam honeycomb. 4. At this point you have three options for finishing off your new cargo organizer. You can: A. spray it with paint to seal the foam. B. Fill it with a light coat of Bondo body filler, sand it smooth and paint it for a cleaner look. C. Fiberglass it, sand it, and then paint it to match your body color. (You can use cans of DupliColor and Clear you don't need to take it to a body shop) Sorry I didn't take photos when we did it. I can tell you it came out great! Im planning on doing it to mine when I eventually get one. Ill post pictures the next time. PROMISE! Are you talking about the Foam around the spare tire? I assumed that ws some type of noise dampening. Does anyone know if that foam has a purpose? Quote Link to comment Share on other sites More sharing options...
BLACK ICE Posted September 29, 2008 Report Share Posted September 29, 2008 Are you talking about the Foam around the spare tire? I assumed that ws some type of noise dampening. Does anyone know if that foam has a purpose? It helps support the load floor also . I was considering a custom particle board and plywood one with fiberglass and paint . Maybe build in some compartments for tools . Quote Link to comment Share on other sites More sharing options...
SMACKyaONdaFACE Posted October 5, 2008 Report Share Posted October 5, 2008 this is something you should take some pics off... i cant even picture what yours looks like. Quote Link to comment Share on other sites More sharing options...
Orion Posted March 23, 2009 Report Share Posted March 23, 2009 I did a smiliar modifcation to my new 2008 Edge; I simply cut out some of the cross pieces inside the styrofoam to make different sized cubby holes. I fit my 4 D-cell Mag light, small tool kits, safety gear, etc. without any major changes to the structural integrity. Woo hoo!! Quote Link to comment Share on other sites More sharing options...
BlazedUp Posted March 24, 2009 Report Share Posted March 24, 2009 Tits :D Quote Link to comment Share on other sites More sharing options...
KMAN Posted April 6, 2009 Report Share Posted April 6, 2009 Any pictures how they turned out? Quote Link to comment Share on other sites More sharing options...
Kanatronic Posted May 9, 2009 Report Share Posted May 9, 2009 No pictures yet? Quote Link to comment Share on other sites More sharing options...
hydro Posted May 10, 2009 Report Share Posted May 10, 2009 What exactly is "cargo management". I have it on my Edge and all I see is.... nothing in the back? Is it supposed to be the spaces around the spare tire after you lift the cover up? Quote Link to comment Share on other sites More sharing options...
Grey Posted May 10, 2009 Report Share Posted May 10, 2009 What exactly is "cargo management". I have it on my Edge and all I see is.... nothing in the back? Is it supposed to be the spaces around the spare tire after you lift the cover up? Yes. You can store cleaners, detail spray, cloths, glass cleaner, jumper cables, tools, etc. in the plastic storage bins around the spare tire. Units without the bin option don't get the tire cover or bins - just foam spacers around the spare. Quote Link to comment Share on other sites More sharing options...
hydro Posted May 10, 2009 Report Share Posted May 10, 2009 Yes. You can store cleaners, detail spray, cloths, glass cleaner, jumper cables, tools, etc. in the plastic storage bins around the spare tire. Units without the bin option don't get the tire cover or bins - just foam spacers around the spare. Cool, thanks I am currently keeping my quick detailer rolled up in a towell behind my drivers seat. I may try the storage areas, but I use the NXT detailer so frequent I don't want to wear the power lift hatch prematurely Quote Link to comment Share on other sites More sharing options...
Kanatronic Posted May 11, 2009 Report Share Posted May 11, 2009 OK let's do this, I give you my foam ones, you give me your cargo management, tire cover included, and I will drop $50.00 on top, given that you do not want to open the trunk prematurely, I think that $50.00 is a good incentive to open it right?..... :shades: Quote Link to comment Share on other sites More sharing options...
hydro Posted May 11, 2009 Report Share Posted May 11, 2009 No Thanks The $50 won't cover the cost of a new linear actuator when it wears out....... of course right after the warranty expires Quote Link to comment Share on other sites More sharing options...
KMAN Posted May 11, 2009 Report Share Posted May 11, 2009 (edited) Some one posted a pic of their Cargo area Its the 11 post in . Edited May 11, 2009 by KMAN Quote Link to comment Share on other sites More sharing options...
Kanatronic Posted May 12, 2009 Report Share Posted May 12, 2009 No Thanks The $50 won't cover the cost of a new linear actuator when it wears out....... of course right after the warranty expires If the linear actuator alone, cost $50.00 it was designed for the NASA... Any linear actuator if you get it yourself will cost you far less, and man do not worry they last a long time before going down, you will sell the car first, that is for sure.... Some one posted a pic of their Cargo area Its the 11 post in . We all know how the original looks like we are talking of the one he made.... Quote Link to comment Share on other sites More sharing options...
Platinum White Posted June 13, 2009 Report Share Posted June 13, 2009 Some one posted a pic of their Cargo area Its the 11 post in . There is nothing there to look at, in the body or an attachment. Quote Link to comment Share on other sites More sharing options...
Kanatronic Posted June 13, 2009 Report Share Posted June 13, 2009 There is nothing there to look at, in the body or an attachment. Post number 11 Quote Link to comment Share on other sites More sharing options...
professorfingers Posted July 23, 2009 Report Share Posted July 23, 2009 I am also intereted in the factory system if it's not to high. My dealers says they are on the Ford Site, but I haven't been able to find them. He also quoted a price of around $80, which I would defintely buy at that price. TW Quote Link to comment Share on other sites More sharing options...
professorfingers Posted July 23, 2009 Report Share Posted July 23, 2009 OK, I called my parts department today. The spare tire cover costs around $80. Each (of two) sides that go around the spare costs around $145 each. So, the whole Cargo Managment System will set you back close to $400 if you go that route. I thin I will look into the spare cover but they can keep their side panels. TW Quote Link to comment Share on other sites More sharing options...
