Transmission hunt
bigmoguls
  bigmoguls said:
'07 mkX FWD.
Doing about 75 (A/C on), cruise on the mkX transmission will downshift (or disengage the torque converter) going over a highway overpass. Anyone else have similar behavior of the transmission hunting for the right gear.
Scott.
I have a similar problem with my 2007 AWD Edge. Going on a downgrade on cruise control at 60 mph it from time to time will down shift a couple of gears where the rpm will top out to 3500
On climbing a twisty grade it will hunt to find a gear and can either under rev or over rev for a couple of seconds. My previous cars like my 2005 Ford Escape just picked out a lower gear and stuck to it smoothly. Did Ford goof on this new type transmission??
S.P. SDchmitt
Shirly you've notice how the thing seems to really free-wheel, on level surface and no gas.
So that's why it picks up speed on a slight downhill and will shift down, to try to maintain your set speed.
They probably should have put a warning in the owners manual about this one too.
