Horn not loud
donlocke65
2011 Ford Edge Horn Removal
1. Remove the 5 RH front fender splash shield screws.
a. Pull the RH front fender splash downward to access the horn.
2. Disconnect the electrical connector.
3 Remove the bolt and the horn.
a. To install, tighten to 10 Nm (89 lb-in)
4. To install, reverse the removal procedure.
Edited by Totally_Ripped
