nonipk Posted November 18, 2014 Report Share Posted November 18, 2014 Hi, I have ford edge 2009 SEL (automatic transmission) . I noticed since yesterday that the shifting is delayed till the speed reached 100 km/h. Rmp reaches till 3 and then the gear shifts and before that engine makes noise since the gear is not automaticallly changed. Last week I replaced transmission fluid also. Please advice. Thanks Quote Link to comment Share on other sites More sharing options...
omar302 Posted November 18, 2014 Report Share Posted November 18, 2014 Did you check the transmission fluid level? Did you refill with the correct type? Quote Link to comment Share on other sites More sharing options...
akirby Posted November 18, 2014 Report Share Posted November 18, 2014 And did you follow the correct procedure to check the level? Sure sounds like low or incorrect fluid. Quote Link to comment Share on other sites More sharing options...
nonipk Posted November 19, 2014 Author Report Share Posted November 19, 2014 Ya I filled with the correct type. Please advice me what is the correct procedure for checking the level. I am checking the level with the engine off and since the oil is very thin so i am facing difficulties in checking level but the mechanic confirmed the level is correct. Quote Link to comment Share on other sites More sharing options...
Duckkarl Posted November 19, 2014 Report Share Posted November 19, 2014 Transmission fluid level must be checked with the engine running. If the level is in the normal range with the engine off, there is not enough fluid in the transmission, thus causing improper operation. Quote Link to comment Share on other sites More sharing options...
akirby Posted November 19, 2014 Report Share Posted November 19, 2014 Not only should the engine be running the transmission should be up to temperature. The procedure is outlined in the owner's manual. Quote Link to comment Share on other sites More sharing options...
Duckkarl Posted November 19, 2014 Report Share Posted November 19, 2014 Good point about transmission being at operating temp. It is important that the fluid be at operating temp, and that the transmission has been shifted to all gears. This ensures that all the different valves and the torque converter have all had fluid pump to them. Any mechanic that says you can check fluid without running the engine needs to go back to school. Quote Link to comment Share on other sites More sharing options...
