transmission shifting problems
jasonsvwbug
Okay start off slams gears from third to fourth gear took to ford and only code is PCM. So the called and wanted me to drive some more to see if more codes will come up still the same but now won't shift out of first and ford said front pump in trans is bad. They can fix for 1100. But it's awd so want to know if I can change it from awd to fwd if I can just change trans and be good . Any help would be great Tia.
Codes are numerical and not Just PCM which stands for power control module (this is the computer that controls just about everything in the car) There should be a specific PCM code stored in the computer to help diagnose the problem. I don't think that you can switch from awd to fwd economically. I would get a second opinion about the repairs.
