Lincoln serviced at Ford dealer
brihvac
I've had all the complimentary oil changes & tire rotations on my 2012 MKX performed through Quick Lane operations at Ford dealerships, based on reminders from the vehicle's Oil-Life Monitor.
Make sure you remind the Ford Quick Lane attendant about your MKX's complimentary maintenance entitlement.
Your MKX's VIN will be entered into Ford's OASIS information system to verify its complimentary maintenance eligibility.
Your 2013 MKX should be entitled to eight complimentary maintenance visits over four-years/50,000 miles, which are broadly described in the attached Lincoln document and here. Lincoln complimentary maintenance is also mentioned in the attached 2013 MKX brochure on the right side of Page 3.
Good luck!
2013 Lincoln Complimentary Maintenance Plan.pdf
2013 MKX Brochure.pdf
