joeponcho Posted October 31, 2014 Report Share Posted October 31, 2014 I am attempting to change the Right Inner Tie Rod on my 2010 Edge. Does anyone know if the end that is threaded into the steering box is "Crimped In" at the factory or is there a pin through it acting as a set screw? I am trying to figure out if it is something I can do myself or if it requires a lift or special tools other than the Tie Rod puller..... Thanks for any help.... Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 31, 2014 Report Share Posted October 31, 2014 The only special tool I see mentioned in the manual is the tie-rod-end-remover, plus a wrench. Other than that, you have to remove the stabilizer bar and steering gear to get at the inner tie rod. The lock washer on the inner tie rod end needs to be crimped. HTH. Quote Link to comment Share on other sites More sharing options...
