nc_edge Posted October 28, 2014 Report Share Posted October 28, 2014 07 edge quit on me yesterday. it would seem to fire up for about two seconds and die. beat on the tank but it did no good. had it towed home. today i went outside and it fired right up. drove it to the parts store and it showed no history of any codes present. im frustrated. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 28, 2014 Report Share Posted October 28, 2014 Sorry to hear, nc_edge! Is the battery pretty new? If it is more than 2-3 years old, it should be replaced. That's where I would start. These random problems start at the battery most times, especially with cooler weather moving in. If that that doesn't fix it, we can look at other possibilities. Please provide update on service history, mileage, etc. Quote Link to comment Share on other sites More sharing options...
nc_edge Posted October 29, 2014 Author Report Share Posted October 29, 2014 Original battery. 126k on odometer. Transmission flash at 30k. plugs and belts at 115k. oil every 5 and trans flush at 60 and 120. i have a new battery. bought a project truck and figured i would use old battery in project until i figured out which direction i was headed with project. battery hold down bolt snapped. while im certain plastic hold down is not threaded, it will not budge. bolt is white from corrosion not rust. today i will see if it will start and try to get battery changed if i have to just hack the hold down to pieces with the dremel. then have battery system and old battery tested. i have a fuel pressure tester that i will tackle today. Quote Link to comment Share on other sites More sharing options...
nc_edge Posted October 29, 2014 Author Report Share Posted October 29, 2014 Battery hold down problem solved. Took battery to get it tested. It did test as a bad battery. I just do not understand how if the battery would start the car, why would fuel pump not run? I would assume it takes more power for the starter versus the fuel pump. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 29, 2014 Report Share Posted October 29, 2014 Don't know. Electronic controls probably not allowing the fuel pump to run. Starter may be unmonitored. Quote Link to comment Share on other sites More sharing options...
