edgesport14 Posted October 19, 2014 Report Share Posted October 19, 2014 Will 17 inch rims off a 2010 edge fit on my 2014 edge sport? I'm looking to get an extra set for winter and found some 17s off a 2010 for $100. Thanks Quote Link to comment Share on other sites More sharing options...
ls973800 Posted October 19, 2014 Report Share Posted October 19, 2014 Not a direct bolt on fit. The hub opening on the 2010 and older models is larger than on the 2011 and newer models. You would have to use a centric hub ring to make up the difference of the larger hub opening on the 2010 wheel. If you were also going to use the TPMS sensor, the 2010 and older models used a band inside the wheel to hold the transmitter, and the 2011 and newer use the valve stem to hold the sensor. The 2011 and up models also use a different frequency than the 2010 and older models for the transmission of the signal. 1 Quote Link to comment Share on other sites More sharing options...
edgesport14 Posted October 19, 2014 Author Report Share Posted October 19, 2014 Thanks for the info! Quote Link to comment Share on other sites More sharing options...
