bankerjohn Posted October 9, 2014 Report Share Posted October 9, 2014 Recently purchased a 2013 Edge SEL and discovered that the left headlight assembly needs to be replaced, as the case is cracked to the point its alignment can't be adjusted (according to the local shop). According to Ford, the correct part # is BT4Z-13008-B ... but the unit that's in the vehicle is BT43-13006-AC. Before I fork out the money for a new assembly, can someone explain this "discrepancy"? Also, does it make sense that a cracked housing can prevent proper alignment? Quote Link to comment Share on other sites More sharing options...
Cellbine Posted October 10, 2014 Report Share Posted October 10, 2014 I had to order new headlights for different reasons. These are the part numbers and prices I paid: BT4Z-13008-A Headlight $319.79 1 BT4Z-13008-B Headlight $319.79 1 http://oemfordparts.jackyjones.com 1 Quote Link to comment Share on other sites More sharing options...
