FamousFacey Posted October 1, 2014 Report Share Posted October 1, 2014 I have had 3Five bulbs with Morimoto ballasts in my edge for about 2-3 months now, and all of a sudden i dont have any passenger side headlight. I checked voltage to the fusebox and out of the fusebox, and voltage is sitting steady at 14V. I checked at the headlight, and i have nothing... Has anybody seen this problem before? I just need to know if it is something that I can fix, or if i will have to take it to ford.. Any help or info would be appreciated. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 1, 2014 Report Share Posted October 1, 2014 Have you tried switching ballast/bulb left-right and see if the problem goes with it? Quote Link to comment Share on other sites More sharing options...
akirby Posted October 1, 2014 Report Share Posted October 1, 2014 No use taking it to Ford if you have aftermarket HIDs. Quote Link to comment Share on other sites More sharing options...
FamousFacey Posted October 1, 2014 Author Report Share Posted October 1, 2014 I dont think this is a Ballast/Bulb issue. There is no voltage even before the ballast, so it could not be the ballast or bulb.. I am thinking it has something to do with the Module that controls the lights. My buddy had the same problem, but it was with both lights, and he had to get ford to reset his module for 80 bucks. I just want to see if anybody else had the same issue and if it was fixable by the owner, before i go and spend $80... Quote Link to comment Share on other sites More sharing options...
akirby Posted October 1, 2014 Report Share Posted October 1, 2014 If it's not getting voltage from the SJB then there is nothing you can do to reset it yourself and Ford is not going to cover it under any type of warranty since it's likely the ballast is what caused it zonk out in the first place. Quote Link to comment Share on other sites More sharing options...
FamousFacey Posted October 1, 2014 Author Report Share Posted October 1, 2014 If it's not getting voltage from the SJB then there is nothing you can do to reset it yourself and Ford is not going to cover it under any type of warranty since it's likely the ballast is what caused it zonk out in the first place. Alright thats what I figured. I Will just have to cough up the $80 then. Thanks Man. Quote Link to comment Share on other sites More sharing options...
akirby Posted October 1, 2014 Report Share Posted October 1, 2014 It never hurts to ask...... Quote Link to comment Share on other sites More sharing options...
