J0J0 Posted September 29, 2014 Report Share Posted September 29, 2014 I bought a 2014 Edge SE AWD in June and I love it! I didn't need all the bells and whistles but AWD was a necessity here in Rockland County, NY. When I first drove the car at night, I wasn't impressed with the headlight illumination so I knew I would be upgrading to HID. I went with the 35W unit from Xenonpro.com and made sure I purchased the warning cancel unit to avoid the hyper flashing. Install went pretty well. The hardest part was figuring out how to mount it where the original HID ballast should have gone. My only problem now is adjusting the headlights. I went through the manual and tried to locate the hex head adjustment. The drawing in the manual doesn't really help. Has anyone adjusted their headlights on their edge? If you have, can you post a picture of where it is? For the life of me, I can't seem to find the hex head adjustment they are referring to. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
akirby Posted September 29, 2014 Report Share Posted September 29, 2014 I did a few years ago. I think the adjuster is inside another plastic piece. Look for a hole you can insert a screwdriver in the general area pointed out in the manual. Quote Link to comment Share on other sites More sharing options...
J0J0 Posted September 29, 2014 Author Report Share Posted September 29, 2014 (edited) Ok, after a beer and rethinking, I finally found them. On the passenger side, just to the right of the dust cap of the headlight bulb enclosure, there is a black part with a WHITE hex head. On the drivers side, it's to the left of the dust cap of the headlight enclosure. Now all I have to do is wait for it to be dark enough to make the slight adjustment for the beams to be even. I will post pics when I can. Edited September 29, 2014 by J0J0 Quote Link to comment Share on other sites More sharing options...
