brantlyj Posted September 24, 2014 Report Share Posted September 24, 2014 I have a 2008 Edge Limited AWD. I'm having a problem with the transmission. When I shift from park into gear it will not go. press the gas and the engine revs up. It will move a little but not more than a walking pace. Only way to correct it is to turn the car off and then on again. Sometimes this needs to be done several times. This is very, very intermittent so it's not something I can take to the shop. It will go for months without issue. I'm sure it's just a sensor or solenoid but not sure what? Anyone have a similar issue and found the solution? Quote Link to comment Share on other sites More sharing options...
akirby Posted September 24, 2014 Report Share Posted September 24, 2014 Check engine light on? If so check the code. Could be the TCM. Quote Link to comment Share on other sites More sharing options...
brantlyj Posted September 24, 2014 Author Report Share Posted September 24, 2014 nope, no CEL and no code. Quote Link to comment Share on other sites More sharing options...
akirby Posted September 24, 2014 Report Share Posted September 24, 2014 How old is the battery? Long shot but weak batteries can cause strange problems. Quote Link to comment Share on other sites More sharing options...
brantlyj Posted September 24, 2014 Author Report Share Posted September 24, 2014 bought it used in 2011. The dealer replaced the battery before we bought it from them Quote Link to comment Share on other sites More sharing options...
akirby Posted September 24, 2014 Report Share Posted September 24, 2014 I've almost never gotten more than 3 years out of a battery. If it was me I'd change it if you get any more problems just to be safe. Quote Link to comment Share on other sites More sharing options...
thirdgenlxi Posted September 25, 2014 Report Share Posted September 25, 2014 Possibly the TSS/OSS sensors.... though those usually set a code. Have you checked the fluid level and condition?? Quote Link to comment Share on other sites More sharing options...
Camshaft Posted September 30, 2014 Report Share Posted September 30, 2014 I am not a ford guy. But, have you tried to wiggle the shift knob then try driving? Possibly a park/drive switch that may be the cause? Quote Link to comment Share on other sites More sharing options...
brantlyj Posted September 30, 2014 Author Report Share Posted September 30, 2014 I had hoped to have a resolution to this. I had to bring it in for a PTU leak. They claimed there were tests that can be done. All they did was drive it around. So I'm no farther than where I was this morning. *sigh* Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 30, 2014 Report Share Posted September 30, 2014 (edited) Were they testing the TSS/OSS sensors or something else, do you know? PTU leak fixed? EDIT: Corrected a misstatement re: yr of Edge for OP. Edited September 30, 2014 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
brantlyj Posted September 30, 2014 Author Report Share Posted September 30, 2014 All they did was take it for a test drive. Since they could not replicate the problem they did nothing further. As for the leak the deal was replaced at 61,000 miles. Now at 76,000 they claim it overheated and is leaking from the case and the entire unit needs to be replaced. Ford covered the leak under goodwill the first time. They wouldn't even ask ford for assistance this time. Considering it started leaking immediately after the seal replacement I feel they screwed up something. I am not pleased at the moment. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 30, 2014 Report Share Posted September 30, 2014 If you feel you have reached a dead-end with your dealer, maybe Todd or Tricia of Ford Customer Service can help. There may be a possibility that PTU fluid replacement could keep it going for some time, but we don't know why it is leaking. Is it the PTU overheating, or is it transmission fluid leaking into the PTU then being vented? What color was the leak? Brownish or reddish? If clearly brown, it is likely PTU fluid, if red, transmission fluid. Quote Link to comment Share on other sites More sharing options...
brantlyj Posted September 30, 2014 Author Report Share Posted September 30, 2014 If you feel you have reached a dead-end with your dealer, maybe Todd or Tricia of Ford Customer Service can help. There may be a possibility that PTU fluid replacement could keep it going for some time, but we don't know why it is leaking. Is it the PTU overheating, or is it transmission fluid leaking into the PTU then being vented? What color was the leak? Brownish or reddish? If clearly brown, it is likely PTU fluid, if red, transmission fluid. I have already been in contact with Todd. But thanks for the suggestion. The fluid is black, thick and sticky. Defiantly gear oil. It's definatly blowing out the vent. I'm not sure it's exactly overheating but I can't offer a better reason. After some searching here it's not that uncommon for this to happen it seems. I guess we will see how it all plays out. If Ford in unable to offer any relieve I will probably replace the PTU myself. I can't afford $800 in labor. Quote Link to comment Share on other sites More sharing options...
FordService Posted October 1, 2014 Report Share Posted October 1, 2014 If you feel you have reached a dead-end with your dealer, maybe Todd or Tricia of Ford Customer Service can help. Thank you for the free advertising, WWWPerfA_ZN0W! I have already been in contact with Todd. But thanks for the suggestion. The fluid is black, thick and sticky. Defiantly gear oil. It's definatly blowing out the vent. I'm not sure it's exactly overheating but I can't offer a better reason. After some searching here it's not that uncommon for this to happen it seems. I guess we will see how it all plays out. If Ford in unable to offer any relieve I will probably replace the PTU myself. I can't afford $800 in labor. I received your PM, brantlyj, and will be replying shortly. Todd 1 Quote Link to comment Share on other sites More sharing options...
