Is the Tow Package Necessary?
I have a '11 Edge SEL AWD and have been looking into purchasing a waverunner lately but before I did I wanted to make sure that I would be able to tow it safely. I know that Ford rates the towing capacity @ 3500lbs and the waverunner + trailer is only going to be about 1000 lbs so that shouldn't be a problem.
My question is do I need to change anything on my Edge to be able to tow this safely? The Ford tow package includes an upgraded radiator, cooling fans and trailer sway control on top of the receive and wiring harness. Is the cooling and sway control add-ons truly necessary? I'm thinking not but figured I'd do my research before investing.
Thanks,
-Russ
I have the 2011 Ford Edge LImited FWD only. So, with the comments stated, the tow package isn't necessary required as long as the towing capacity stays under 2000 lbs? I sold my tacoma truck for the Edge and now I am researching my options for a hitch and harness assembly to tow my Sea Doo Ski (1000 +/- 200 lbs). I am assuming that cutting the rear lower panel for proper hitch installation depends on the brand/type of hitch. I would definitely prefer not to modify the rear panel for installation purposes. Suggestions and recommendations are greatly appreciated.
