Replacement of an automatic transmission fluid of yellow color. Questions.
EDST777
Hello guys. I own FORD EDGE 2008 Limited AWD 3.5. My run of 114 000 km. I wish to replace an automatic transmission fluid in an automatic transmission and there are problems in the solution of this business. I don't know what automatic transmission fluid was filled in pregoing time because I am the second owner, the car was shipped on 83 000 km. According to the user manual replacement by Dexton VI is recommended, usually it is liquid of red color, for example as here:
on 06.18 minute. But I filled in yellow liquid and I don't know a brand. I think to make full replacement independently three times that I worry to mix liquids. Whether report someone on services applied a yellow automatic transmission fluid? Whether replacement on red is possible, for example, after all the part of liquid, even small, remains not replaced? As far as my replacement and how me to avoid possible troubles will be dangerous? Thanks. Edited by EDST777
If you are not currently experiencing any problems, don't worry about remaining "yellow" mixing in with the "red" fluid. Do the 3x exchange with the "red" fluid, make sure there are no metallic particles in the fluid you drain, and you should be good to go as far as fluid is concerned. For the 2008 Ford Edge, you should be using Mercon V, not Dexron anything.
Pg 325
http://www.fordservicecontent.com/Ford_Content/catalog/owner_guides/08edgog1e.pdf
Automatictransmission fluid 10.0 quarts (9.5L)3 Motorcraft MERCON V ATF
XT-5-QM / MERCON V
Rear differential(AWD) fluid 2.4 pints (1.15L) Motorcraft SAE 80W-90 Premium Rear Axle Lubricant
XY-80W90-QL / WSP-M2C197-A
Power Transfer Unit (PTU) fluid (AWD) 12 ounces (0.35L) Motorcraft SAE 75W-140 Synthetic Rear Axle Lubricant
XY-75W140-QL / WSL-M2C192-A
Edited by WWWPerfA_ZN0W
Guys, I have no opportunity at present to get Motorcraft Mercon V liquid, but I have opportunity to get Valvoline MaxLife ATF liquid
On packing admissions are specified:
Valvoline ATF MaxLife 12 Liter in 12Dosen zu je 1L
empfohlen für alle Fahrzeuge mit mehr als 100.000 Km Laufleistung
Freigaben/Leistungsstufen:
GM Dexron IID, IIE, III, VI
Ford Mercon, Mercon V
Allison C-4, TransSynd, TES-295
BMW LT 71141, LA 2634
MAN 339 Ausgabe Z1, Z2, V1, V2
Mazda
Mini Cooper CVT EXL 799
Toyota T, T-11, T-IV
Chrysler ATF+3
Mitsubishi Diamond SP-II, SP-III
Honda ATF-Z1
Nissan D, J, K, - matic
Volvo 1161521, 1161540
Audi G0520250A2
GM9986195
ZF-TE-ML-14B, 16L, 17C
JWS 3309
Voith G607, 1363
KIA SP-II, SP-III
Suzuki
VW
TL 52162
Mercedes-Benz: 236.01 236.02, 236.03, 236.05, 236.06, 236.07, 236.08, 236.09, 236.10 und 236.11
und weitere
Color of liquid - red. Me excites that there are no instructions on XT-5-QM. I can use this liquid for replacement? What your opinion?
