CheetahCats Posted August 11, 2014 Report Share Posted August 11, 2014 Hi Folks - I tried doing a search on this topic, however I was unable to see any topics which matches this enquiry. Hope it's not a redundant question. Does anyone know if it is possible to enable/view the rear camera display while the vehicle is in "drive" gear? Any guidance would be appreciated. Thanks, CC Quote Link to comment Share on other sites More sharing options...
omar302 Posted August 11, 2014 Report Share Posted August 11, 2014 (edited) You can enable a "Delay" feature in Vehicle>Camera settings of the main (center) screen. This will enable keeping the revers camera on when moving from Reverse to Drive and the Camera will remain on until you reach a certain speed (~5-8 mph, don't remember exactly). But to keep the Camera on in Drive at any other speed cannot be done unless you install an aftermarket kit such as this http://www.coastaletech.com/mytouch2.htm. Edited August 11, 2014 by omar302 2 Quote Link to comment Share on other sites More sharing options...
CheetahCats Posted August 11, 2014 Author Report Share Posted August 11, 2014 You can enable a "Delay" feature in Vehicle>Camera settings of the main (center) screen. This will enable keeping the revers camera on when moving from Reverse to Drive and the Camera will remain on until you reach a certain speed (~5-8 mph, don't remember exactly). But to keep the Camera on in Drive at any other speed cannot be done unless you install an aftermarket kit such as this http://www.coastaletech.com/mytouch2.htm. Thanks for the guidance. I appreciate it. Quote Link to comment Share on other sites More sharing options...
