2011 Edge Limited Gear Indicator No Longer Illuminates
Took our 2011 Limited to the dealership to have an issue looked into and I also brought to their attention that the gear indicator next to the shift no longer illuminates. They were able to fix my first issue and they called Ford regarding the shift indicator. Ford claims that in order to fix this issue that it is going to cost $1,000 as there are significant parts that need to be replaced and the lighting has specific sequences and it's more than just a blown bulb. Anyone at all have any experience with this issue and what it takes to fix it?
Thanks
  • 4 months later...
Found this info about the TSB above:
http://www.explorerforum.com/forums/showpost.php?p=3364343
TSB 14-0209
SHIFT TO PARK MESSAGE - WHILE IN PARK / UNABLE TO REMOVE
IKT / SHIFTER STUCK IN PARK / DISCHARGED BATTERY DUE TO
SHIFT TO PARK LIGHT ON
FORD:
2011-2014 Edge
2013-2014 Flex
2011-2015 Explorer
2013-2015 Taurus
LINCOLN:
2013-2014 MKS, MKT
2011-2015 MKX
ISSUE
Some 2011-2014 Edge, 2011-2015 MKX, Explorer, 2013-2014 Flex, MKT, MKS and 2013-2015 Taurus vehicles equipped
with a floor shift selector lever may exhibit a Shift To Park message displayed while in park, unable to remove integrated
keyhead transmitter (IKT), shifter stuck in park and/or discharged battery due to Shift to Park light remaining illuminated.
The park detect switch cannot detect the shifter is in park.
SERVICE PROCEDURE
1. Replace the selector lever assembly.
And since it is a TSB it only falls under Factory Warranty Guidelines. IE 3/36 and any purchased extended warranty. If you are outside of this you pay.
  • 6 months later...
