Shadrack Posted July 31, 2014 Report Share Posted July 31, 2014 (edited) Has anyone had a bad wheel bearing go down with 30k miles?? We bought our 2013 Ford Edge Sport with 23k miles a few months ago. LOVE it, but we drove it to the beach and back and we've noticed several issues arise over the trip it seems like, it now has 30k miles on it. There is a distinct howl/growl coming from the front end, it's the loudest at 40-45mph. Very noticeable at 70mph interstate driving (sounds like severe road noise). Anyone else had this issue? Thought it may be the stock 22" Pirrelli's (they are junk tires, IMO) but after rotating, the noise has not changed. It also pulls fairly hard to the right as well. Also, the sync system has had a critical error message and shut down the other day, and also on my last oil change, I noticed quite a bit of oil residue around the PTU seal. I called a friend that works for Ford and he is scheduling it for a closer look before the 36k mile warranty is up. Just wonder if anyone has had sync issues, wheel bearing, and PTU leak at 30k miles? I hope this isn't a sign to come. If the PTU has to be taken out, I'd love to be able to install a fill/drain plug in it somehow like the thread on here, but I know that wont happen at a Ford dealer. Edited August 1, 2014 by Shadrack Quote Link to comment Share on other sites More sharing options...
arabski Posted January 6, 2015 Report Share Posted January 6, 2015 hi! have you addressed your wheel noise issue? my edge just turned 40k and I am experiencing the same (I believe) thing. I didnt even realise how loud my car became lately until I drove MKX... it is just madness - this rotation noise gets bit louder when I break - dealer told me it is definitelly tires (22" pirelli), but I couldnt disagree more - the tires visually look perfect and there is still 6mm thread left on them. Wheel bearing? Or something else? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 6, 2015 Report Share Posted January 6, 2015 I too would suspect the wheel bearing if the tires look OK. Does the noise change in sound when you turn the wheel in either direction? That would strengthen the case for WB. Quote Link to comment Share on other sites More sharing options...
arabski Posted January 6, 2015 Report Share Posted January 6, 2015 ...not really, it is more or less constant moaming... but you can only hear it when the car goes 40+ km/h... Quote Link to comment Share on other sites More sharing options...
PaulSchott Posted January 6, 2015 Report Share Posted January 6, 2015 You can rotate the tires and see if the sound moves with the tire in question. I thought I had a bad bearing and found out it was a tire when I replaced all of them. I actually needed tires anyway but the tire looked ok at first glance. Quote Link to comment Share on other sites More sharing options...
akirby Posted January 6, 2015 Report Share Posted January 6, 2015 On 1/6/2015 at 12:44 PM, arabski said: ...not really, it is more or less constant moaming... but you can only hear it when the car goes 40+ km/h... I get that from the passenger seat if I take corners too fast. Sometimes it escalates to screams....... 1 Quote Link to comment Share on other sites More sharing options...
PaulSchott Posted January 9, 2015 Report Share Posted January 9, 2015 Ha Ha, Just got that after reading it twice. I have the same problem, It's not under warrantee. Maybe lemon law. Quote Link to comment Share on other sites More sharing options...
arabski Posted January 11, 2015 Report Share Posted January 11, 2015 i rotated wheels, fixed pressure (from 45-42 down to 35 - weird) and it seems better now (at least I do not hear this cyclic moaming anymore). So point for everyone saying it was the rubber, not bearing... Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 11, 2015 Report Share Posted January 11, 2015 Fingers crossed it stays quiet Haven't seen that behavior from "overinflated" tires before, unless they are worn to that point and you are turning the vehicle. Quote Link to comment Share on other sites More sharing options...
macbwt Posted January 11, 2015 Report Share Posted January 11, 2015 I would say bearing, but so few miles to really consider a bearing. Wheel bearings make noise based on speed and comes and goes with turning while driving down the highway. Rule of thumb is if you have to turn the radio up to hear it then it is a wheel bearing. At least this has been true for my Edge. I have replaced 6 so far. 1 Quote Link to comment Share on other sites More sharing options...
Shadrack Posted March 27, 2015 Author Report Share Posted March 27, 2015 Mine ended up being tires. Junky Pirilli's! Quote Link to comment Share on other sites More sharing options...
macbwt Posted March 27, 2015 Report Share Posted March 27, 2015 Not really sure which is cheaper to fix new tires or new wheel bearing. I think I will go with the wheel bearing. On 3/27/2015 at 12:38 PM, Shadrack said: Mine ended up being tires. Junky Pirilli's! 1 Quote Link to comment Share on other sites More sharing options...
arabski Posted April 11, 2015 Report Share Posted April 11, 2015 (edited) I started regularly rotating my wheels ... the noise problem is kinda solved - at least the most irritating humming is gone now. But every 10k km I cycle all wheels clockwise. I did it twice so far and I am happy with this so far, but my tires will need a replacement soon... Edited April 11, 2015 by arabski Quote Link to comment Share on other sites More sharing options...
LUPID Posted September 3, 2015 Report Share Posted September 3, 2015 My 2011 had a bad front right wheel bearing before I bought it. The salesman at the dealership try to tell me the sound was asphalt shooting up into the wheel well. I made him look at it and fix it before I would buy it. Good to know it happens to the vehicles. Quote Link to comment Share on other sites More sharing options...
