Engine Swap
just4kicks247
You might want to follow this post where another owner is installing a different engine into his 2007 Edge. He was supposed to be getting the used engine today. Might want to private message him for details about removal/installation if he doesn't post any guidelines as he does it.
http://www.fordedgeforum.com/topic/15001-engine-swap/?do=findComment&comment=115022
From what the manual is telling me, you can remove the engine/trans as an assembly from the top, but the PTU does have to come off.
Try the Chilton manual's section on Engine/Mechanical to get to this info:
http://www.fordedgeforum.com/topic/13205-chilton-2007-13-ford-edge-manual-available/?do=findComment&comment=103079
Edited by WWWPerfA_ZN0W
