Really Loud Brake Sqeeking In Reverse Only--2010 Edge
Car has about 45k miles on it. Started noticing light squeeking when braking in reverse a few months back. Had brake pads replaced in March by a local mechanic (not at Ford). He said rotors were fine. For a few days the car was fine. Then it started squeeking again (when braking in reverse). Over the weeks it gradually got worse and worse. Now it is embarassingly loud. Sounds awful. Never squeeks while moving forward.
Any clues????
Thanks
Happens all the time in reverse or just when starting up/moving the Edge? Is the emergency brake releasing fully? If you let the Edge sit long enough, mild rust develops on the rotors, which gets scrubbed off during initial braking. The rears seem to be more prone to this problem, maybe due to the emergency brake setup? Have the calipers checked to make sure they are not binding, and have the slide pins lubricated.
  • 3 months later...
