Looking at a 2012 sel
sal878
Hi guys and gals just trying to get some info on these edges. Other than the dreaded ptu issue, is there any other things I should look out for when buying a edge? Or if you guys can point me in the right direction on the forums. I am looking at a 2012 sel for the wife. Thanks
Edited by sal878
Run through the usual checklist for any vehicle: drives well, shifts well with no hesitation/jerkiness, no clunks/clicks/rattles, no leaking fluids, fluid color, smell & level ok, no unusual smells in cabin, etc. Compare to a new Edge if you can.
Then, specific to the Edge:
PTU (although I think mostly happened to the 2007-10 crowd) issue (check under car for signs of leaks)
A/C should operate & drain properly (should see water puddles on the ground; air should be cold)
Door Latch Ajar problem (primarily driver front door) - door should close without effort
Panoramic Vista Roof (lovingly called a BAMR) - should operate easily and quietly. May want to get a deflector for the roof so any road trash doesn't hit it.
Liftgate (rear hatch) should open & close with normal effort. If it is a manual liftgate, might want to slam it shut kinda hard a couple of times to make sure the glass doesn't shatter. Rare, but does happen.
Bubbling or rust on the paint
GPS & navigation should be accurate
Satellite Radio should work (if you have the service)
PCM Programming up to date
MFT/Sync up to date
Cabin Air Filter should be new, and clean
I'm sure others will be glad to add on :) HTH.
Edited by WWWPerfA_ZN0W
