oskar27 Posted July 13, 2014 Report Share Posted July 13, 2014 I wonder if there is a better way to dim (together and at the same time) the lights on the Instrument Cluster and SYNC screen at night. What I do now is a two step process which I find quite difficult and dangerous: First I use the Instrument Lighting Dimmer switch (located to the left of the steering column) to dim the Instrument Cluster lights and then I have to find the menu on the SYNC screen to dim the SYNC light which is quite bright. Then the next day I have to do the same process to increase the light level in both. Perhaps there is an easier way described in the manual which I missed? Quote Link to comment Share on other sites More sharing options...
nickf1011 Posted July 13, 2014 Report Share Posted July 13, 2014 Is it a MFT-equipped vehicle? If so, one of the options on the screen brightness menu is to have them both dim to whatever settings you have them set to automatically based on ambient light conditions. Quote Link to comment Share on other sites More sharing options...
oskar27 Posted July 13, 2014 Author Report Share Posted July 13, 2014 Yes it is MFT equipped and I just found a setting "Auto Dimm" which was set to OFF. Now I put it to "AUTO" and I will see if it works when it gets dark outside Thanks Quote Link to comment Share on other sites More sharing options...
nickf1011 Posted July 14, 2014 Report Share Posted July 14, 2014 Yes it is MFT equipped and I just found a setting "Auto Dimm" which was set to OFF. Now I put it to "AUTO" and I will see if it works when it gets dark outside Thanks That should be the one! Happy to help. Quote Link to comment Share on other sites More sharing options...
